Can a Tiny Drone Navigate Home Without a Map? What Role Does LiDAR Play?
Small drones face a fundamental challenge: autonomous navigation often demands significant computing power, yet onboard processing capacity, memory, and energy are extremely limited.
A recent study, Efficient Robot Navigation Inspired by Honeybee Learning Flights, explores an interesting alternative.
The researchers developed Bee-Nav, a navigation strategy that combines path integration with a lightweight visual homing neural network, reducing the need for detailed environmental maps.
  1. How Can a Drone Find Its Way Home Without a Detailed Map?
The approach takes inspiration from honeybees, which perform short learning flights to familiarize themselves with their surroundings before traveling farther from the hive.
Similarly, the drone first performs a short learning flight around its starting location, capturing omnidirectional images along the way. Meanwhile, path integration provides estimated home vectors that serve as training labels for a small neural network.
Once trained, the system relies on two complementary navigation mechanisms:
  • Path Integration: Estimates the direction and distance back to the starting point using accumulated motion information, allowing the drone to follow a relatively direct return path.
  • Visual Homing: Uses learned visual information from the home environment to correct errors that accumulate during path integration.
What makes this approach particularly interesting is that the neural network does not need to build or store a detailed map of the entire flight area.
However, this raises another important question: Path integration depends on continuous motion estimation. Where does that motion information come from?
  1. Why Did the Researchers Combine Optical Flow and LiDAR?
In small-drone navigation, optical flow sensors can detect the apparent movement of ground textures. However, there is a fundamental limitation: optical flow alone cannot directly determine the drone’s true horizontal velocity without additional information about distance to the observed surface.
Consider a drone flying at the same horizontal speed but at different altitudes.
When flying close to the ground, surface textures move rapidly across the sensor’s field of view. At higher altitudes, the same horizontal motion produces slower apparent image movement.
This is where LiDAR rangefinding becomes important.
In this study, the researchers used the Benewake TFmini-S LiDAR to measure the drone’s distance to the ground.
By combining this distance measurement with optical flow observations, the system gains the scale information needed to support horizontal motion estimation.
In simpler terms, optical flow tells the system how the ground image is moving, while LiDAR provides the distance reference needed to relate that image motion to real-world movement.
Meanwhile, the IMU supplies acceleration and angular velocity measurements. These complementary sensor inputs are fused through state estimation to support the drone’s motion and position estimates.
This sensor configuration illustrates a practical approach to navigation on resource-constrained platforms: combining optical flow, LiDAR, and inertial sensing to support motion estimation without relying entirely on computationally intensive vision processing.
  1. What Does This Sensor Combination Mean for Small-Drone Development?
For engineers developing compact autonomous drones, the study highlights several useful design considerations.
First, LiDAR range measurements help address the scale ambiguity of optical flow.
Optical flow describes relative image motion, while LiDAR provides a distance reference that helps translate those observations into meaningful motion estimates.
This is particularly relevant when estimating horizontal velocity and displacement.
Second, independent range measurements provide additional information for vertical position estimation.
When reliable GPS altitude information is unavailable, a downward-facing rangefinder can measure the drone’s distance above the ground and provide an additional input for state estimation.
However, this measurement has limitations. It depends on valid ground returns and should not be confused with absolute altitude. Uneven terrain, vehicle tilt, and operation beyond the sensor’s effective range may require additional compensation or filtering.
Finally, lightweight navigation algorithms still depend on reliable low-level motion estimation.
Bee-Nav reduces the need for large environmental maps and computationally expensive visual processing, but that does not eliminate the importance of onboard sensors.
For resource-constrained drones, carefully distributing perception tasks across optical flow, LiDAR, inertial sensing, and visual learning may be more practical than simply increasing onboard computing power.
  1. What Did the Experiments Demonstrate?
The researchers demonstrated autonomous flight in real-world environments using neural networks as small as 3.4 KB and 42 KB.
In the reported flight experiments covering distances of 30–110 meters, the drones successfully returned to within 0.5 meters of their starting positions in all reported tests.
However, longer outdoor flights remain challenging, particularly under strong winds and changing visual conditions.
These results suggest that practical autonomous navigation does not necessarily require large neural networks or computationally expensive mapping systems.
One important distinction is worth emphasizing: LiDAR was used primarily for ground-distance measurement, not for visual homing or environmental mapping. The reported navigation performance reflects the complete system rather than the contribution of any single sensor.
The broader engineering question is an interesting one:
For small autonomous drones, could a well-designed combination of lightweight sensors and efficient algorithms be more valuable than adding more computing power?
ABOUT TF mini-S LiDAR:Benewake TFmini-S Micro Lidar | Original Brand Manufacturer
Interesting research, particularly the combination of lightweight visual homing and path integration for resource-constrained UAVs.
One aspect worth exploring further is how the system handles accumulated position uncertainty when optical flow or range measurements become temporarily unreliable.
For practical PX4 integration, I see several important questions:
  1. How does the navigation system detect and handle optical-flow degradation over low-texture or repetitive surfaces?
  2. How sensitive is the visual homing network to illumination changes and environments with similar visual features?
  3. What happens when the downward-facing LiDAR loses valid ground returns or operates outside its reliable measurement range?
  4. Can the visual homing output be integrated with PX4’s existing state-estimation architecture without introducing conflicting position estimates?
  5. How does the system determine when its return-home estimate is no longer sufficiently reliable?
The distinction between navigation performance and navigation confidence is particularly important.
A lightweight system that can return home is valuable. A system that can also identify when its return-home estimate is becoming unreliable would be even more useful for real-world autonomous operations.
It would be interesting to see additional experiments involving repetitive indoor environments, changing illumination, and temporary sensor degradation.
Thanks for sharing this work.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
