I have a pixhawk1 controller from years ago. I use 4 ESC instead of the integrated ESC. When I plug in the battery, I can hear the buzzer going on. I can see the lights coming on on the GPS. However none of the motors start. Is there something else I have to configure to get that to start?
- Are you getting any messages on QGC after you connect it to the FC?
- Have you calibrated the ESCs individually directly connected to your Rx?
- Have you calibrated your radio to make sure your end points are registering correctly?
- If you haven’t yet, it’s always a good idea to completely go through the setup and calibration procedures as sequenced in QGC.
Good luck.
Thanks! I’ll try it out.
