Hello!
My laboratory have two Iris+ with pixhawk, I have a battery problem with one.
when I connect the battery to Iris+, I get the following error
The led of the Iris+ is yellow.
I believe that the battery is not problem, because, If I connect the baterry to other iris+, the iris+ works.
What is the cause of the problem?
Regards!
dagar
November 10, 2017, 4:29pm
2
Is USB connected to the pixhawk?
@dagar
Yes, I have USB cable connected to pixhawk
dagar
November 10, 2017, 7:35pm
4
That’s the problem. If it’s to a companion computer you can use telem2 (+adaptor) instead. Don’t power the autopilot over USB for flight (it’s okay for bench testing).
thanks for reply! @dagar
maybe, I do not explain correctly the problem.
I made a video about of my problem.
my test is with the same battery
Hello! @dagar
i was able to solve my problem, I changed the voltage divider parameter in qgrouncontrol.
