I’m trying to make VISUAL_POSITION_ESTIMATE messages work. After a lot of trial and error, I ended up creating a very basic sample program, that simply feeds the position & orientation that PX4 reports for the drone in the form of VISUAL_POSITION_ESTIMATE messages. My expectation was that this would be a noop, as the visual position sent to PX4 is the same that it already has calculated.
The result is that one can’t even arm the drone in such a setup.
If one arms the drone and takes off without considering the VISUAL_POSITION_ESTIMATE messages, then starts to consider them after the drone is airborne, the drone will end up tumbling & moving erratically.
I wonder what I’m doing wrong, and how to make VISUAL_POSITION_ESTIMATE messages work. Any help is appreciated.
Details of the experiment:
I have a PX4 SITL setup using AirSim, as descrived here: AirSim Simulation · PX4 Developer Guide . I’m using the latest master for the PX4 Firmware. the ./build/posix_sitl_default/bin/px4 executable is started from the source directory. the PX4 startup script is this one: PX4 init script - Pastebin.com
after startup, I start my minimal VISUAL_POSITION_ESTIMATE app, which is based on the mavlink_upd.c sample code, here is the source: PX4 visual update sample - Pastebin.com
if I start PX4 with considering visual position estimates, I can’t even arm it:
pxh> param set EKF2_AID_MASK 25
+ EKF2_AID_MASK: curr: 1 -> new: 25
pxh> INFO [ecl/EKF] EKF commencing external vision position fusion
INFO [ecl/EKF] EKF commencing external vision yaw fusion
pxh> INFO [ecl/EKF] EKF GPS checks passed (WGS-84 origin set, using GPS height)
INFO [ecl/EKF] EKF commencing GPS fusion
pxh> commander arm
WARN [commander_tests] PREFLIGHT FAIL: EKF INTERNAL CHECKS
ERROR [commander] arming failed
of I start it with GPS-only, I can arm & take off, but then it will time out on the fusion and the drone will tumble / move around:
pxh> commander arm
pxh> INFO [logger] Start file log
INFO [logger] Opened log file: ./log/2018-08-21/15_11_20.ulg
pxh>
pxh>
pxh> commander takeoff
pxh> INFO [commander] Takeoff detected
pxh> WARN [ecl/EKF] EKF GPS fusion timeout - reset to GPS
tumbling is related to the fusion timeout events noted above.
I wonder what I’m doing wrong, and what is the simplest way to get a naive dummy sample of VISUAL_POSITION_ESTIMATE messages working.
Akos
