Can the Pixhawk controllers can be used for Autopiloting the car? If yes, can you pls help me by giving some pdf literature explaining the same.
Regards,
X Ignatius
Regards,
X Ignatius
@Ignatius rover is supported in px4: https://docs.px4.io/v1.9.0/en/airframes/airframe_reference.html#rover
Thank you very much. Is there any step by step procedure which can be followed, if I need to develop from the scratch.
Regards,
X Ignatius
You can start with going throught https://docs.px4.io/v1.9.0/en/getting_started/
then depending on what you want to do take a look at https://dev.px4.io/v1.9.0/en/setup/getting_started.html
The cable which comes along with GPS/Compass sensor, switch, etc., are very short in length. Can I extend this cable using additional cables. Will there be any effect in the control system due to long cable length. Since I will be using this in a Real car(Not a toy car), all the cables must be extended to get connected to the pixhawk controller.
Can I proceed doing it.
Regards,
Ignatius
Regards,
X Ignatius
The compass sensor is communicates via I2C and will suffer if you extend the cable length - the clock and data lines will be subject to noise and possible crosstalk. The GPS is a serial connection and could also suffer - but you could improve this using a shielded, twisted pair cable.
These systems weren’t designed to be run these kinds of lengths (more than a few inches), which is why cars have all the sensors and systems connected via CAN, which is designed for these distances.
Thanks for your comments. Can I still use the short length cables inside a car, so that I can avoid noise problems as you said. Do you have any pictures of pixhawk connected inside the car.
Regards,
Ignatius
It sounds like your best approach is to start with building a small rover where your safety risk is much lower, and once you understand the basics you can start scaling it up.
