I am looking at post-flight logs, specifically IMU data, and want to see how similar the redundant IMU readouts are. However, after using the ulog2csv script, I am only seeing one IMU readout (MPU9250) in the sensor combined csv. Is there any way for me to find a log of what the other redundant sensors were reading during a flight?
Will changing that param only allow me to do sensor comparisons after running a test? I was hoping I would be able to compare the triple redundant IMU data after parsing the .ulg file.?
Yep, the parameter worked. My original hope would be to compare IMU data on past tests. However, I see this is not possible since I did not have the parameter set for that.
