@rroche @dagar I’ve quickly hacked some XSL to generate this HTML docs page:
http://mavlink.org/meta/airframes
From this XML:
http://px4-travis.s3.amazonaws.com/Firmware/master/airframes.xml
We need now to complete our meta info in all startup scripts and to generate graphics using HTML (ideally it would not be a table, but a graphic with the Pixhawk or Pixracer (in tabs) depicted on the left and what to connect on the right hand). You can then select which hardware you have in a tab.
@dagar @AndreasAntener @anton-matosov @Mark_Whitehorn I would appreciate if you could help drive the dev community to do a good job with meta info in parallel to @rroche working out how to complete the XSL and pretty it up further.
