Hi all,
Currently Iām building Y3 type VTOL which tilt all props(left, right, tail) just after takeoff with Pixhawk & PX4.
When I try to find proper airframe in QGC, I couldnāt.
Any one can help for my issue?
Should I add new code in px4?
Hi all,
Try this one:
Thank you for your advice, but this frame is for Y6(6 props) and does not support tail tilt.
In that case you would have to create a custom mixer.
Please see https://dev.px4.io/en/airframes/adding_a_new_frame.html#mixer-file
Thank you very much, I will check and share the result with you.
There is a āE-flite convergenceā frame defined in the drop down menu of that category, which might be what you looking for.
Edit: i did not notice your requirement on all-tilt-rotor. So in that case you need custom mixer as @sanderux suggested.
