Dear All
We are trying to use a Pixhawk2.1 and connect an X8R telemetry module along with a FrSKY Taranis X9D.
We tried to connect the SBUS output (X8R) to RCin (Cube) but it does not work (the led on the X8R keeps blinking red and no bound - the Taranis has been configured to bind with X8R)
I read different threads on that topic and I am a bit confused because some proposed the SBUS and other said that you need a dedicated cable from SPORT (X8R) to a Serial (either TELEM 1 or 2 on the Cube).
Which wiring is actually correct and why SBUS (X8R) -> RCin (Cube) is not working because with the PixRacer, for instance, this is the correct way to plug the X8R...
Thank you for your support
