I’m excepted to realized a steady flight at 2.5m from the ground in mission mode. But as you can see in the video below the drone is “jumping” which is of course not desired :
Do you have any idea where does it come from?
Could it be a power problem mangement ?
Interferences that could disturb sensors? (I’m in a soccer field and there is some garden hoses in the ground … )
That looks rather weird. What controller Brand/Type do you use? Did you shield Baro from Propeller Downwash/Turbulence? Could also be caused by bad Vibration Dampening. A log would be really helpfull. Does it always happen? Also in PosCtrl Mode or AltitudeMode?
