I’m a novice,when i read the code in commander.cpp i find something like :
// CIRCUIT BREAKERS
status_flags.circuit_breaker_engaged_power_check = false;
status_flags.circuit_breaker_engaged_airspd_check = false;
status_flags.circuit_breaker_engaged_enginefailure_check = false;
status_flags.circuit_breaker_engaged_gpsfailure_check = false;
what does the circuit_breaker mean?is it something about hardware?
Thanks!
Yes,your thinking is right.
The circuit breaker check is used to check whether we can arm.
Circuit Breakers are Softflags you will find in the Parameterlist. This is used to allow the User to enable/disable some security/safety Checks that are used for Arming. i.e. you can permit Arming when a USB Cable is attached, or permit Arming even if there is a Problem with the GPS.
Thanks for the reply ,it 's really helpful.
Thank you.your explain is so clear! thank you.
