Hi guys!
Iām planing to build my first VTOL tailsitter. Have only built āstandardā 5-mot. VTOLs yet.
I was thinking about what kind of weathervaning would make sense for a tailsitter.
In my opinion the best bahavior in stronger wind would be:
Detecting where the wind comes from, and turn one wingtip into the wind. Because this way the plane has much less area facing the wind.
It could work like this:
In Position-mode, plane detects that it needs a pitch angle of -20Ā° (relative to vertical) constantly to hold position. It must notice āah this means the wind is facing directly from the front.ā. As a result turn roll axis by 90Ā°, to point one wingtip into the wind.
Repeat as long, until pitch axis is 0Ā° (meaning vertical in this case).
So kind of a pitch-to-roll-behavior.
Is is possible to adjust such a behavior in PX4?
Or what does the already implemented weathervane function do in tailsitters?
Thank you!
Best regards,
Andi
