At some point my pusher motor stoped working.
I figured out that issue is about calibration.
When drone is powered up it not works.
And if I run ESC calibration it plays some melody and sometimes even works until first reboot.
The most reliable way to calibrate I’ve found is as follows
fw_attitude control stop
pwm -d /dev/pwm_output1 arm
pwm -d /dev/pwm_output1 test -c 4 -p 2000
pwm -d /dev/pwm_output1 test -c 4 -p 900
Then it starts rotating.
fw_attitude control start
But after reboot the situation repeats.
I think there is something with init scripts I changed at some point which prevents motor from working as it was working some time ago. but I can’t figure what what exactly and don’t have the old config unfortunately.
And this is what my init script looks like now:
# @output MAIN1 motor 1
# @output MAIN2 motor 2
# @output MAIN3 motor 3
# @output MAIN4 motor 4
# @output MAIN5 motor 5
# @output MAIN6 motor 6
# @output MAIN7 motor 7
# @output MAIN8 motor 8
# @output AUX1 Ailerons
# @output AUX2 Elevator
# @output AUX3 Rudder
# @output AUX4 Throttle
# @output AUX5 Flaps
sh /etc/init.d/rc.vtol_defaults
if [ $AUTOCNF == yes ]
then
param set VT_TYPE 2
param set VT_MOT_COUNT 8
fi
set MIXER octo_cox
set MIXER_AUX vtol_AERTF_ranger
set PWM_ACHDIS 4
set PWM_AUX_DISARMED 900
set PWM_AUX_RATE 400
set PWM_AUX_MIN 900
set PWM_AUX_OUT 12345
set MAV_TYPE 22
param set UAVCAN_ENABLE 3
param set CBRK_IO_SAFETY 22027
The controller is pixhawk 4
