Using more than 8 motors with UAVCAN
Hi!
Could somebody pls point me on how to allow more than 8 motors to work with UAVCAN?
There is a comment on that in UAVCAN module stating one group (I believe this is an output group as per docs) is limited to 8 outputs max.
  1. Which are the steps to add support for more than 8 motors?
  2. Does output group strictly associated with output device like /dev/pwm_output0, /dev/pwm_output1, /dev/uavcan/esc etc? Or one such device could be used by multiple output groups?
  3. Why pwm_out_sim module is perfectly fine about 16 outputs in mixer file with single ouput device (with this command in init script: pwm_out_sim mode_pwm16)?
So with some dirty hacks it worked but this is not a clear solution. Too many stuff in code rely on this 8 motors max restriction.
uavcan_main.cpp and esc.cpp are subjects to some small changes in order to make this work. Still this is a hack not a solution.
did you find a solution to this problem? I would be also interested, thanks!
