I’m currently working with the intel drone below :
https://click.intel.com/intel-aero-ready-to-fly-drone.html
I would like to transfert some code from Matlab-Simulink by using the PSP solution below :
To do so I configure some parameters in the “Configuration Parameters” of my Simulink simulation (Figure 1). The main one are in red rectangular below. Then I click apply.
Figure 1
In the next step I click on the build Icon inside the red square Figure 2. The building process seems to be perfomed properly as a succesfull message appears and some folder are created by the program at the root path.
Figure 2
Then I try to upload the program as you can see Figure 3.
Figure 3
Then the message Figure 4 appears and the program seems to be block here.
Figure 4
It looks like we have a connection problem or something is not launch correctly but we didn’t really identify the cause of the problem and how to solve it…
Do you have any suggestion ?
Thank you,
Jeremy
