Hi!
I’m trying to build px4 for my vtol. Also i have esc’s connected via uavcan, so i need to enable uavcan module.
I’m trying to modify cmake/configs/nuttx_px4fmu-v2_default.cmake. But, unfortunately, after i enabled uavcan, firmware ceased to fit into memory. I tried to disable unnecessary modules, but this did not help much, the limit is still exceeded by ~ 40 kilobytes.
Hardware:
- px4fmu-v2
- airspeed sensor
- 4 esc connected via uavcan + 5 esc connected via pwm
- PX4FLOW + it’s onboard sonar
- external gps + compass
CMAKE output:
-- Build Type: MinSizeRel
-- PX4 VERSION: v1.6.5-1619-g29af234
-- CONFIG: nuttx_px4fmu-v2_default
-- The ASM compiler identification is GNU
-- Found assembler: /opt/gcc-arm-none-eabi-6-2017-q1-update/bin/arm-none-eabi-gcc
-- Found PythonInterp: /usr/bin/python (found version "2.7.12")
-- Found PY_jinja2: /usr/local/lib/python2.7/dist-packages/jinja2
-- C compiler: arm-none-eabi-gcc (GNU Tools for ARM Embedded Processors 6-2017-q1-update) 6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512]
-- C++ compiler: arm-none-eabi-g++ (GNU Tools for ARM Embedded Processors 6-2017-q1-update) 6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512]
-- Building and including px4io-v2
-- Using C++03
-- Release build type: MinSizeRel
-- Adding UAVCAN STM32 platform driver
-- NuttX: px4fmu-v2 nsh cortex-m4
-- ROMFS: px4fmu_common
Modified config:
include(nuttx/px4_impl_nuttx)
px4_nuttx_configure(HWCLASS m4 CONFIG nsh ROMFS y ROMFSROOT px4fmu_common IO px4io-v2)
set(config_uavcan_num_ifaces 2)
set(config_module_list
# Board support modules
drivers/device
drivers/stm32
drivers/stm32/adc
drivers/stm32/tone_alarm
drivers/led
drivers/px4fmu
drivers/px4io
drivers/boards
drivers/rgbled
drivers/mpu6000
#drivers/mpu9250
drivers/lsm303d
drivers/l3gd20
drivers/hmc5883
drivers/ms5611
#drivers/mb12xx
#drivers/srf02
#drivers/sf0x
#drivers/sf1xx
#drivers/ll40ls
#drivers/teraranger
drivers/gps
#drivers/pwm_out_sim
#drivers/hott
#drivers/hott/hott_telemetry
#drivers/hott/hott_sensors
#drivers/blinkm
drivers/airspeed
#drivers/ets_airspeed
#drivers/ms4525_airspeed
#drivers/ms5525_airspeed
#drivers/sdp3x_airspeed
#drivers/frsky_telemetry
modules/sensors
#drivers/mkblctrl
drivers/px4flow
#drivers/oreoled
#drivers/vmount
drivers/pwm_input
#drivers/camera_trigger
#drivers/bst
#drivers/snapdragon_rc_pwm
drivers/lis3mdl
#drivers/iridiumsbd
#drivers/ulanding
# System commands
systemcmds/bl_update
systemcmds/config
#systemcmds/dumpfile
#systemcmds/esc_calib
systemcmds/hardfault_log
systemcmds/mixer
#systemcmds/motor_ramp
systemcmds/mtd
systemcmds/nshterm
systemcmds/param
systemcmds/perf
systemcmds/pwm
systemcmds/reboot
#systemcmds/sd_bench
systemcmds/top
#systemcmds/topic_listener
systemcmds/ver
# Testing
#drivers/sf0x/sf0x_tests
#drivers/test_ppm
#lib/rc/rc_tests
#modules/commander/commander_tests
#lib/controllib/controllib_test
#modules/mavlink/mavlink_tests
#modules/uORB/uORB_tests
#systemcmds/tests
# General system control
modules/commander
modules/events
modules/load_mon
modules/navigator
modules/mavlink
modules/gpio_led
modules/uavcan
#modules/land_detector
#modules/camera_feedback
# Estimation modules
#modules/attitude_estimator_q
#modules/position_estimator_inav
#modules/local_position_estimator
modules/ekf2
# Vehicle Control
modules/fw_att_control
modules/fw_pos_control_l1
#modules/gnd_att_control
#modules/gnd_pos_control
modules/mc_att_control
modules/mc_pos_control
modules/vtol_att_control
# Logging
modules/logger
#modules/sdlog2
# Library modules
modules/systemlib/param
modules/systemlib
modules/systemlib/mixer
modules/uORB
modules/dataman
# Libraries
lib/controllib
lib/mathlib
lib/mathlib/math/filter
lib/ecl
lib/geo
lib/geo_lookup
lib/conversion
lib/launchdetection
lib/led
lib/terrain_estimation
lib/runway_takeoff
lib/tailsitter_recovery
lib/version
lib/DriverFramework/framework
platforms/nuttx
# had to add for cmake, not sure why wasn't in original config
platforms/common
platforms/nuttx/px4_layer
# OBC challenge
#examples/bottle_drop
# Rover apps
#examples/rover_steering_control
# Demo apps
#examples/math_demo
# Tutorial code from
# https://px4.io/dev/px4_simple_app
#examples/px4_simple_app
# https://px4.io/dev/daemon
#examples/px4_daemon_app
# https://px4.io/dev/debug_values
#examples/px4_mavlink_debug
# https://px4.io/dev/example_fixedwing_control
#examples/fixedwing_control
# Hardware test
#examples/hwtest
Maybe it’s possible to turn off something else? Or to do something else?
