Hi Devs,
At some point in the past, the two main instruments (art horizon and heading indicator) were displayed above and below (respectively) the values widget, rather than side by side at the top.
- Was there a specific reason for this change? Just increasing real-estate available for the map?
- Is this just determined by a hidden setting somewhere, so it’s possible to switch between the two layouts without major code changes, or is it pretty permanent?
Cheers,
Edwin
