Hi everyone. Iāve been building a tilt-rotor quad-plane based around the Mini Talon (v-tail). As if that wasnāt difficult enough Iāve decided to use the new Pixhawk 4 from Holybro which seems untested amongst the community.
In my build, the front motor arm is a single rod connected through 2 bearings to one centralised servo so that I have no offset issues from using separate servos. Iām at the point now that Iām looking at the best airframe to use. From what I can see, there isnt a stock airframe that covers what I need so Iām looking for a little help on which one to load up please.
Iāve tried to load the generic āquadplane AAVVTā but for some reason I cant get the customised cfg and mixer to load from the microsd. On that mixer I change the order on the aux channels to AVVT (I have a Y cable for the Ailerons and T is for tilt on this one). Seems like I may be in over my head because Iāve hit a brick wall.
Is there an airframe profile that would be better suited to my needs? Iāve seen some specifically for tilt-rotors but it seems they dont have V tail support as standard.
Iām primarily a builder and flier and much less a programmer so Iām starting to struggle. Any help and guidance would be very much appreciated please.
Al
