The Tutorial is Broken
I’m trying to follow the tutorial, but get stuck on this page:
http://dev.px4.io/en/apps/hello_sky.html
the links under “Build the Application/Firmware” don’t go anywhere, it appears that the files necessary to the tutorial do not exist.
Thanks for the note. If you are working with master, you can look at the docs here which are more up-to-date: https://dev.px4.io/master/en/apps/hello_sky.html
Thank you. It appears that I was working with “stable (v1.8.2)”. I’m very new here and wasn’t aware of this.
