Hello, I’m trying to do a little change to the mc_pos_control_main.cpp . And now I have a question about the control rate. There is a “dt” doing time updating in the code. Is there a fixed control rate? Thank you!
It runs when there’s a new local position update from the estimator.
Is this “pret” decide the control rates?
/* wait for up to 20ms for data */
int pret = px4_poll(&fds[0], (sizeof(fds) / sizeof(fds[0])), 20);
/* timed out - periodic check for _task_should_exit */
if (pret == 0) {
// Go through the loop anyway to copy manual input at 50 Hz.
/* this is undesirable but not much we can do */
if (pret < 0) {
warn("poll error %d, %d", pret, errno);
continue;
For I want to change the code to control the vehicle in another way, and a sample rate is needed. As what you said, there doesn’t exist a fixed rate?
The way this is structured it runs in step with position updates published by the estimator. You should calculate a dt if needed.
