I am trying to do temperature calibration a pixhawk 2.1 board, but am not having much luck.
I am following the directions here for offboard calibration:
https://docs.px4.io/en/advanced_config/sensor_thermal_calibration.html#offboard_calibration
I am using the offboard technique. First I cold soak the board for about 30 minutes @ -30C. Then I raise the temperature up over the next 30 minutes to +70C. At this point I power down the pixhawk and run the python script.
The resulting output is very strange.
First attempt is here:
https://review.px4.io/plot_app?log=99c5751b-8270-45a0-89af-e460686b5b34
17_54_03.ulg.pdf (309.0 KB)
Why is there no data in the middle of the log? This attempt had a much faster ramp on temperature, so the log is shorter.
Second attempt here:
https://review.px4.io/plot_app?log=9dee8922-142d-4482-b32a-d1f44ddfacf5
log001.ulg.pdf (1.4 MB)
Why is the log only 20 minutes? I had the system in the test chamber for at least an hour. Was data lost due to removing the power? How do I shut the board down to close the log file properly?
Why are the graphs over such a small temperature range, and why is that range different for each sensor?
Without the calibration I get massive errors on the accelerometers in the cold (-5C or so). “sensors status” shows a 1G discrepancy between some of the axes.
Also, does SENS_EN_THERMAL have any usage?
