[solved]Pixracer does not arm
Hi guys,
For some reason my Pixracer is not arming, I tried different things such as different firmwares, arm through radio and etc but I had no success. I attached some images to help explain, the QGroundControl log file and also the parameters file and the very end.
Please guys let me know if you guys have some ideas. Thank you all.
----- QGroundControl Log file -------
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/QGCApplication.cc:263 - “Settings location “/Users/ronildo/.config/org.qgroundcontrol/QGroundControl.ini” Is writable?: false”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/QGCLoggingCategory.cc:99 - “Filter rules “qt.network.ssl.warning=false\n*Log.debug=false\nLinkManagerLog.debug=true\nMultiVehicleManagerLog.debug=true\n””
[!] at :0 - “No text-to-speech plug-ins were found.”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/PositionManager/PositionManager.cpp:39 - “QObject(0x0)”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/Vehicle/MAVLinkLogManager.cc:359 - “MAVLink logs directory: “/Users/ronildo/Documents/QGroundControl/Logs””
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/QtLocationPlugin/QGCMapEngine.cpp:216 - “Map Cache in: “/Users/ronildo/Library/Caches/QGCMapCache300” / “qgcMapCache.db””
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/comm/LinkManager.cc:468 - “New auto-connect UDP port added”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/comm/LinkManager.cc:548 - "Waiting for next autoconnect pass “/dev/cu.usbmodem1"”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/comm/LinkManager.cc:592 - "New auto-connect port added: “PX4 FMU V4 on cu.usbmodem1 (AutoConnect)” “/dev/cu.usbmodem1"”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/comm/MAVLinkProtocol.cc:436 - “Temp log “/var/folders/3r/0_l2jv093w7c1nqh047fnbl00000gp/T/FlightData562942.mavlink””
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/Vehicle/MultiVehicleManager.cc:110 - “Adding new vehicle link:vehicleId:componentId:vehicleFirmwareType:vehicleType “/dev/cu.usbmodem1” 1 1 12 2”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/Vehicle/MultiVehicleManager.cc:256 - “setActiveVehicle Vehicle(0x7fcfa3523000)”
[D] at /Users/travis/build/mavlink/qgroundcontrol/src/Vehicle/MultiVehicleManager.cc:281 - “_setActiveVehiclePhase2 _vehicleBeingSetActive Vehicle(0x7fcfa3523000)”
[I] at /Users/travis/build/mavlink/qgroundcontrol/src/FactSystem/ParameterManager.cc:771 - “Attemping load from cache”
[I] at /Users/travis/build/mavlink/qgroundcontrol/src/FactSystem/ParameterManager.cc:819 - “Parameters loaded from cache /Users/ronildo/.config/org.qgroundcontrol/ParamCache/1_1.v2”
[E] at file:///Applications/QGroundControl.app/Contents/Resources/qml/QtQuick/Dialogs/DefaultFileDialog.qml:210 - “file:///Applications/QGroundControl.app/Contents/Resources/qml/QtQuick/Dialogs/DefaultFileDialog.qml:210:25: QML ListView: Binding loop detected for property “model””
----- Parameters file -------
Onboard parameters for Vehicle 1
Stack: PX4 Pro
Vehicle: Multi-Rotor
Version: 1.7.3 dev
Git Revision: df322971629af379
Vehicle-Id Component-Id Name Value Type
1 1 BAT_A_PER_V 36.367515563964843750 9
1 1 BAT_CAPACITY -1.000000000000000000 9
1 1 BAT_CNT_V_CURR 0.000805664050858468 9
1 1 BAT_CNT_V_VOLT 0.000805664050858468 9
1 1 BAT_CRIT_THR 0.070000000298023224 9
1 1 BAT_EMERGEN_THR 0.050000000745058060 9
1 1 BAT_LOW_THR 0.150000005960464478 9
1 1 BAT_N_CELLS 4 6
1 1 BAT_R_INTERNAL -1.000000000000000000 9
1 1 BAT_SOURCE 0 6
1 1 BAT_V_CHARGED 4.050000190734863281 9
1 1 BAT_V_DIV 13.653333663940429688 9
1 1 BAT_V_EMPTY 3.500000000000000000 9
1 1 BAT_V_LOAD_DROP 0.300000011920928955 9
1 1 BAT_V_OFFS_CURR 0.000000000000000000 9
1 1 CAL_ACC0_EN 1 6
1 1 CAL_ACC0_ID 3737098 6
1 1 CAL_ACC0_XOFF 0.046715736389160156 9
1 1 CAL_ACC0_XSCALE 1.001295924186706543 9
1 1 CAL_ACC0_YOFF 0.160699844360351563 9
1 1 CAL_ACC0_YSCALE 0.993372023105621338 9
1 1 CAL_ACC0_ZOFF -0.556575775146484375 9
1 1 CAL_ACC0_ZSCALE 1.004758000373840332 9
1 1 CAL_ACC1_EN 1 6
1 1 CAL_ACC1_ID 1442826 6
1 1 CAL_ACC1_XOFF -0.129863739013671875 9
1 1 CAL_ACC1_XSCALE 1.000081062316894531 9
1 1 CAL_ACC1_YOFF 0.146129608154296875 9
1 1 CAL_ACC1_YSCALE 1.001288890838623047 9
1 1 CAL_ACC1_ZOFF -0.051997661590576172 9
1 1 CAL_ACC1_ZSCALE 0.996541798114776611 9
1 1 CAL_ACC2_XOFF 0.000000000000000000 9
1 1 CAL_ACC2_XSCALE 1.000000000000000000 9
1 1 CAL_ACC2_YOFF 0.000000000000000000 9
1 1 CAL_ACC2_YSCALE 1.000000000000000000 9
1 1 CAL_ACC2_ZOFF 0.000000000000000000 9
1 1 CAL_ACC2_ZSCALE 1.000000000000000000 9
1 1 CAL_ACC_PRIME 3737098 6
1 1 CAL_AIR_CMODEL 0 6
1 1 CAL_AIR_TUBED_MM 1.500000000000000000 9
1 1 CAL_AIR_TUBELEN 0.200000002980232239 9
1 1 CAL_BARO_PRIME 0 6
1 1 CAL_GYRO0_EN 1 6
1 1 CAL_GYRO0_ID 3802634 6
1 1 CAL_GYRO0_XOFF -0.016901744529604912 9
1 1 CAL_GYRO0_XSCALE 1.000000000000000000 9
1 1 CAL_GYRO0_YOFF 0.003412622492760420 9
1 1 CAL_GYRO0_YSCALE 1.000000000000000000 9
1 1 CAL_GYRO0_ZOFF -0.007403769064694643 9
1 1 CAL_GYRO0_ZSCALE 1.000000000000000000 9
1 1 CAL_GYRO1_EN 1 6
1 1 CAL_GYRO1_ID 2360330 6
1 1 CAL_GYRO1_XOFF 0.003291379194706678 9
1 1 CAL_GYRO1_XSCALE 1.000000000000000000 9
1 1 CAL_GYRO1_YOFF 0.014832922257483006 9
1 1 CAL_GYRO1_YSCALE 1.000000000000000000 9
1 1 CAL_GYRO1_ZOFF 0.013135405257344246 9
1 1 CAL_GYRO1_ZSCALE 1.000000000000000000 9
1 1 CAL_GYRO2_XOFF 0.000000000000000000 9
1 1 CAL_GYRO2_XSCALE 1.000000000000000000 9
1 1 CAL_GYRO2_YOFF 0.000000000000000000 9
1 1 CAL_GYRO2_YSCALE 1.000000000000000000 9
1 1 CAL_GYRO2_ZOFF 0.000000000000000000 9
1 1 CAL_GYRO2_ZSCALE 1.000000000000000000 9
1 1 CAL_GYRO_PRIME 3802634 6
1 1 CAL_MAG0_EN 1 6
1 1 CAL_MAG0_ID 73225 6
1 1 CAL_MAG0_ROT 0 6
1 1 CAL_MAG0_XOFF 0.106412447988986969 9
1 1 CAL_MAG0_XSCALE 1.062074661254882813 9
1 1 CAL_MAG0_YOFF 0.110680893063545227 9
1 1 CAL_MAG0_YSCALE 0.955341756343841553 9
1 1 CAL_MAG0_ZOFF 0.099819548428058624 9
1 1 CAL_MAG0_ZSCALE 0.990501165390014648 9
1 1 CAL_MAG1_EN 1 6
1 1 CAL_MAG1_ID 66826 6
1 1 CAL_MAG1_ROT -1 6
1 1 CAL_MAG1_XOFF 0.072111532092094421 9
1 1 CAL_MAG1_XSCALE 1.050090193748474121 9
1 1 CAL_MAG1_YOFF -0.101995512843132019 9
1 1 CAL_MAG1_YSCALE 0.989699840545654297 9
1 1 CAL_MAG1_ZOFF -0.124217398464679718 9
1 1 CAL_MAG1_ZSCALE 0.968992948532104492 9
1 1 CAL_MAG2_EN 1 6
1 1 CAL_MAG2_ID 263178 6
1 1 CAL_MAG2_ROT -1 6
1 1 CAL_MAG2_XOFF 0.268020749092102051 9
1 1 CAL_MAG2_XSCALE 0.980291485786437988 9
1 1 CAL_MAG2_YOFF 0.474966615438461304 9
1 1 CAL_MAG2_YSCALE 0.959053099155426025 9
1 1 CAL_MAG2_ZOFF 0.023463694378733635 9
1 1 CAL_MAG2_ZSCALE 1.060713291168212891 9
1 1 CAL_MAG3_ID 0 6
1 1 CAL_MAG3_ROT -1 6
1 1 CAL_MAG3_XOFF 0.000000000000000000 9
1 1 CAL_MAG3_XSCALE 1.000000000000000000 9
1 1 CAL_MAG3_YOFF 0.000000000000000000 9
1 1 CAL_MAG3_YSCALE 1.000000000000000000 9
1 1 CAL_MAG3_ZOFF 0.000000000000000000 9
1 1 CAL_MAG3_ZSCALE 1.000000000000000000 9
1 1 CAL_MAG_PRIME 73225 6
1 1 CAL_MAG_SIDES 63 6
1 1 CBRK_AIRSPD_CHK 0 6
1 1 CBRK_ENGINEFAIL 284953 6
1 1 CBRK_FLIGHTTERM 121212 6
1 1 CBRK_GPSFAIL 0 6
1 1 CBRK_IO_SAFETY 22027 6
1 1 CBRK_RATE_CTRL 0 6
1 1 CBRK_SUPPLY_CHK 0 6
1 1 CBRK_USB_CHK 0 6
1 1 CBRK_VELPOSERR 0 6
1 1 COM_ARM_AUTH 256010 6
1 1 COM_ARM_EKF_AB 0.002400000113993883 9
1 1 COM_ARM_EKF_GB 0.000869999988935888 9
1 1 COM_ARM_EKF_HGT 1.000000000000000000 9
1 1 COM_ARM_EKF_POS 0.500000000000000000 9
1 1 COM_ARM_EKF_VEL 0.500000000000000000 9
1 1 COM_ARM_EKF_YAW 0.500000000000000000 9
1 1 COM_ARM_IMU_ACC 0.699999988079071045 9
1 1 COM_ARM_IMU_GYR 0.250000000000000000 9
1 1 COM_ARM_MAG 0.150000005960464478 9
1 1 COM_ARM_MIS_REQ 0 6
1 1 COM_ARM_SWISBTN 0 6
1 1 COM_ARM_WO_GPS 1 6
1 1 COM_DISARM_LAND 0 6
1 1 COM_DL_LOSS_T 10 6
1 1 COM_DL_REG_T 0 6
1 1 COM_EF_C2T 5.000000000000000000 9
1 1 COM_EF_THROT 0.500000000000000000 9
1 1 COM_EF_TIME 10.000000000000000000 9
1 1 COM_FLIGHT_UUID 0 6
1 1 COM_FLTMODE1 -1 6
1 1 COM_FLTMODE2 -1 6
1 1 COM_FLTMODE3 -1 6
1 1 COM_FLTMODE4 -1 6
1 1 COM_FLTMODE5 -1 6
1 1 COM_FLTMODE6 -1 6
1 1 COM_HOME_H_T 5.000000000000000000 9
1 1 COM_HOME_V_T 10.000000000000000000 9
1 1 COM_LOW_BAT_ACT 0 6
1 1 COM_OBL_ACT 0 6
1 1 COM_OBL_RC_ACT 0 6
1 1 COM_OF_LOSS_T 0.000000000000000000 9
1 1 COM_POSCTL_NAVL 0 6
1 1 COM_POS_FS_DELAY 1 6
1 1 COM_POS_FS_GAIN 10 6
1 1 COM_POS_FS_PROB 30 6
1 1 COM_RC_ARM_HYST 1000 6
1 1 COM_RC_IN_MODE 0 6
1 1 COM_RC_LOSS_T 0.500000000000000000 9
1 1 COM_RC_OVERRIDE 0 6
1 1 COM_RC_STICK_OV 12.000000000000000000 9
1 1 COM_TAKEOFF_ACT 0 6
1 1 EKF2_ABIAS_INIT 0.200000002980232239 9
1 1 EKF2_ABL_ACCLIM 25.000000000000000000 9
1 1 EKF2_ABL_GYRLIM 3.000000000000000000 9
1 1 EKF2_ABL_LIM 0.400000005960464478 9
1 1 EKF2_ABL_TAU 0.500000000000000000 9
1 1 EKF2_ACC_B_NOISE 0.003000000026077032 9
1 1 EKF2_ACC_NOISE 0.349999994039535522 9
1 1 EKF2_AID_MASK 1 6
1 1 EKF2_ANGERR_INIT 0.100000001490116119 9
1 1 EKF2_ARSP_THR 0.000000000000000000 9
1 1 EKF2_ASPD_MAX 20.000000000000000000 9
1 1 EKF2_ASP_DELAY 100.000000000000000000 9
1 1 EKF2_AVEL_DELAY 5.000000000000000000 9
1 1 EKF2_BARO_DELAY 0.000000000000000000 9
1 1 EKF2_BARO_GATE 5.000000000000000000 9
1 1 EKF2_BARO_NOISE 2.000000000000000000 9
1 1 EKF2_BCOEF_X 25.000000000000000000 9
1 1 EKF2_BCOEF_Y 25.000000000000000000 9
1 1 EKF2_BETA_GATE 5.000000000000000000 9
1 1 EKF2_BETA_NOISE 0.300000011920928955 9
1 1 EKF2_DECL_TYPE 7 6
1 1 EKF2_DRAG_NOISE 2.500000000000000000 9
1 1 EKF2_EAS_NOISE 1.399999976158142090 9
1 1 EKF2_EVA_NOISE 0.050000000745058060 9
1 1 EKF2_EVP_NOISE 0.050000000745058060 9
1 1 EKF2_EV_DELAY 175.000000000000000000 9
1 1 EKF2_EV_GATE 5.000000000000000000 9
1 1 EKF2_EV_POS_X 0.000000000000000000 9
1 1 EKF2_EV_POS_Y 0.000000000000000000 9
1 1 EKF2_EV_POS_Z 0.000000000000000000 9
1 1 EKF2_FUSE_BETA 0 6
1 1 EKF2_GBIAS_INIT 0.100000001490116119 9
1 1 EKF2_GPS_CHECK 21 6
1 1 EKF2_GPS_DELAY 110.000000000000000000 9
1 1 EKF2_GPS_POS_X 0.000000000000000000 9
1 1 EKF2_GPS_POS_Y 0.000000000000000000 9
1 1 EKF2_GPS_POS_Z 0.000000000000000000 9
1 1 EKF2_GPS_P_GATE 5.000000000000000000 9
1 1 EKF2_GPS_P_NOISE 0.500000000000000000 9
1 1 EKF2_GPS_V_GATE 5.000000000000000000 9
1 1 EKF2_GPS_V_NOISE 0.500000000000000000 9
1 1 EKF2_GYR_B_NOISE 0.001000000047497451 9
1 1 EKF2_GYR_NOISE 0.014999999664723873 9
1 1 EKF2_HDG_GATE 2.599999904632568359 9
1 1 EKF2_HEAD_NOISE 0.300000011920928955 9
1 1 EKF2_HGT_MODE 0 6
1 1 EKF2_IMU_POS_X 0.000000000000000000 9
1 1 EKF2_IMU_POS_Y 0.000000000000000000 9
1 1 EKF2_IMU_POS_Z 0.000000000000000000 9
1 1 EKF2_MAGBIAS_ID 73225 6
1 1 EKF2_MAGBIAS_X 0.000000000000000000 9
1 1 EKF2_MAGBIAS_Y 0.000000000000000000 9
1 1 EKF2_MAGBIAS_Z 0.000000000000000000 9
1 1 EKF2_MAGB_K 0.200000002980232239 9
1 1 EKF2_MAGB_VREF 0.000000249999999369 9
1 1 EKF2_MAG_ACCLIM 0.500000000000000000 9
1 1 EKF2_MAG_B_NOISE 0.000099999997473788 9
1 1 EKF2_MAG_DECL 0.000000000000000000 9
1 1 EKF2_MAG_DELAY 0.000000000000000000 9
1 1 EKF2_MAG_E_NOISE 0.001000000047497451 9
1 1 EKF2_MAG_GATE 3.000000000000000000 9
1 1 EKF2_MAG_NOISE 0.050000000745058060 9
1 1 EKF2_MAG_TYPE 0 6
1 1 EKF2_MAG_YAWLIM 0.250000000000000000 9
1 1 EKF2_MIN_OBS_DT 20 6
1 1 EKF2_MIN_RNG 0.100000001490116119 9
1 1 EKF2_NOAID_NOISE 10.000000000000000000 9
1 1 EKF2_OF_DELAY 5.000000000000000000 9
1 1 EKF2_OF_GATE 3.000000000000000000 9
1 1 EKF2_OF_N_MAX 0.500000000000000000 9
1 1 EKF2_OF_N_MIN 0.150000005960464478 9
1 1 EKF2_OF_POS_X 0.000000000000000000 9
1 1 EKF2_OF_POS_Y 0.000000000000000000 9
1 1 EKF2_OF_POS_Z 0.000000000000000000 9
1 1 EKF2_OF_QMIN 1 6
1 1 EKF2_OF_RMAX 2.500000000000000000 9
1 1 EKF2_PCOEF_XN 0.000000000000000000 9
1 1 EKF2_PCOEF_XP 0.000000000000000000 9
1 1 EKF2_PCOEF_Y 0.000000000000000000 9
1 1 EKF2_PCOEF_Z 0.000000000000000000 9
1 1 EKF2_REQ_EPH 5.000000000000000000 9
1 1 EKF2_REQ_EPV 8.000000000000000000 9
1 1 EKF2_REQ_GDOP 2.500000000000000000 9
1 1 EKF2_REQ_HDRIFT 0.300000011920928955 9
1 1 EKF2_REQ_NSATS 6 6
1 1 EKF2_REQ_SACC 1.000000000000000000 9
1 1 EKF2_REQ_VDRIFT 0.500000000000000000 9
1 1 EKF2_RNG_AID 0 6
1 1 EKF2_RNG_A_HMAX 5.000000000000000000 9
1 1 EKF2_RNG_A_IGATE 1.000000000000000000 9
1 1 EKF2_RNG_A_VMAX 1.000000000000000000 9
1 1 EKF2_RNG_DELAY 5.000000000000000000 9
1 1 EKF2_RNG_GATE 5.000000000000000000 9
1 1 EKF2_RNG_NOISE 0.100000001490116119 9
1 1 EKF2_RNG_PITCH 0.000000000000000000 9
1 1 EKF2_RNG_POS_X 0.000000000000000000 9
1 1 EKF2_RNG_POS_Y 0.000000000000000000 9
1 1 EKF2_RNG_POS_Z 0.000000000000000000 9
1 1 EKF2_RNG_SFE 0.050000000745058060 9
1 1 EKF2_TAS_GATE 3.000000000000000000 9
1 1 EKF2_TAU_POS 0.250000000000000000 9
1 1 EKF2_TAU_VEL 0.250000000000000000 9
1 1 EKF2_TERR_GRAD 0.500000000000000000 9
1 1 EKF2_TERR_NOISE 5.000000000000000000 9
1 1 EKF2_WIND_NOISE 0.100000001490116119 9
1 1 FW_ARSP_MODE 0 6
1 1 GF_ACTION 1 6
1 1 GF_ALTMODE 0 6
1 1 GF_COUNT -1 6
1 1 GF_MAX_HOR_DIST 0.000000000000000000 9
1 1 GF_MAX_VER_DIST 0.000000000000000000 9
1 1 GF_SOURCE 0 6
1 1 GPS_DUMP_COMM 0 6
1 1 GPS_UBX_DYNMODEL 7 6
1 1 IMU_ACCEL_CUTOFF 30.000000000000000000 9
1 1 IMU_GYRO_CUTOFF 30.000000000000000000 9
1 1 LNDMC_ALT_MAX -1.000000000000000000 9
1 1 LNDMC_FFALL_THR 2.000000000000000000 9
1 1 LNDMC_FFALL_TTRI 0.300000011920928955 9
1 1 LNDMC_ROT_MAX 20.000000000000000000 9
1 1 LNDMC_THR_RANGE 0.100000001490116119 9
1 1 LNDMC_XY_VEL_MAX 1.500000000000000000 9
1 1 LNDMC_Z_VEL_MAX 0.500000000000000000 9
1 1 LND_FLIGHT_T_HI 0 6
1 1 LND_FLIGHT_T_LO 67659839 6
1 1 MAV_BROADCAST 0 6
1 1 MAV_COMP_ID 1 6
1 1 MAV_FWDEXTSP 1 6
1 1 MAV_PROTO_VER 0 6
1 1 MAV_RADIO_ID 0 6
1 1 MAV_SYS_ID 1 6
1 1 MAV_TEST_PAR 1 6
1 1 MAV_TYPE 2 6
1 1 MAV_USEHILGPS 0 6
1 1 MC_ACRO_EXPO 0.689999997615814209 9
1 1 MC_ACRO_P_MAX 720.000000000000000000 9
1 1 MC_ACRO_R_MAX 720.000000000000000000 9
1 1 MC_ACRO_SUPEXPO 0.699999988079071045 9
1 1 MC_ACRO_Y_MAX 540.000000000000000000 9
1 1 MC_BAT_SCALE_EN 0 6
1 1 MC_PITCHRATE_D 0.003000000026077032 9
1 1 MC_PITCHRATE_FF 0.000000000000000000 9
1 1 MC_PITCHRATE_I 0.050000000745058060 9
1 1 MC_PITCHRATE_MAX 220.000000000000000000 9
1 1 MC_PITCHRATE_P 0.150000005960464478 9
1 1 MC_PITCH_P 6.500000000000000000 9
1 1 MC_PITCH_TC 0.200000002980232239 9
1 1 MC_PR_INT_LIM 0.300000011920928955 9
1 1 MC_RATT_TH 0.800000011920928955 9
1 1 MC_ROLLRATE_D 0.003000000026077032 9
1 1 MC_ROLLRATE_FF 0.000000000000000000 9
1 1 MC_ROLLRATE_I 0.050000000745058060 9
1 1 MC_ROLLRATE_MAX 220.000000000000000000 9
1 1 MC_ROLLRATE_P 0.150000005960464478 9
1 1 MC_ROLL_P 6.500000000000000000 9
1 1 MC_ROLL_TC 0.200000002980232239 9
1 1 MC_RR_INT_LIM 0.300000011920928955 9
1 1 MC_TPA_BREAK_D 1.000000000000000000 9
1 1 MC_TPA_BREAK_I 1.000000000000000000 9
1 1 MC_TPA_BREAK_P 1.000000000000000000 9
1 1 MC_TPA_RATE_D 0.000000000000000000 9
1 1 MC_TPA_RATE_I 0.000000000000000000 9
1 1 MC_TPA_RATE_P 0.000000000000000000 9
1 1 MC_YAWRATE_D 0.000000000000000000 9
1 1 MC_YAWRATE_FF 0.000000000000000000 9
1 1 MC_YAWRATE_I 0.100000001490116119 9
1 1 MC_YAWRATE_MAX 200.000000000000000000 9
1 1 MC_YAWRATE_P 0.200000002980232239 9
1 1 MC_YAWRAUTO_MAX 45.000000000000000000 9
1 1 MC_YAW_FF 0.500000000000000000 9
1 1 MC_YAW_P 2.799999952316284180 9
1 1 MC_YR_INT_LIM 0.300000011920928955 9
1 1 MIS_ALTMODE 1 6
1 1 MIS_DIST_1WP 900.000000000000000000 9
1 1 MIS_DIST_WPS 900.000000000000000000 9
1 1 MIS_LTRMIN_ALT -1.000000000000000000 9
1 1 MIS_MNT_YAW_CTL 0 6
1 1 MIS_TAKEOFF_ALT 2.500000000000000000 9
1 1 MIS_YAWMODE 1 6
1 1 MIS_YAW_ERR 12.000000000000000000 9
1 1 MIS_YAW_TMT -1.000000000000000000 9
1 1 MNT_MODE_IN -1 6
1 1 MOT_SLEW_MAX 0.000000000000000000 9
1 1 MPC_ACC_DOWN_MAX 10.000000000000000000 9
1 1 MPC_ACC_HOR 5.000000000000000000 9
1 1 MPC_ACC_HOR_FLOW 0.500000000000000000 9
1 1 MPC_ACC_HOR_MAX 10.000000000000000000 9
1 1 MPC_ACC_UP_MAX 10.000000000000000000 9
1 1 MPC_ALT_MODE 0 6
1 1 MPC_CRUISE_90 3.000000000000000000 9
1 1 MPC_DEC_HOR_SLOW 5.000000000000000000 9
1 1 MPC_HOLD_DZ 0.100000001490116119 9
1 1 MPC_HOLD_MAX_XY 0.800000011920928955 9
1 1 MPC_HOLD_MAX_Z 0.600000023841857910 9
1 1 MPC_JERK_MAX 0.000000000000000000 9
1 1 MPC_JERK_MIN 1.000000000000000000 9
1 1 MPC_LAND_ALT1 10.000000000000000000 9
1 1 MPC_LAND_ALT2 5.000000000000000000 9
1 1 MPC_LAND_SPEED 0.699999988079071045 9
1 1 MPC_MANTHR_MAX 0.899999976158142090 9
1 1 MPC_MANTHR_MIN 0.079999998211860657 9
1 1 MPC_MAN_TILT_MAX 35.000000000000000000 9
1 1 MPC_MAN_Y_MAX 200.000000000000000000 9
1 1 MPC_THR_HOVER 0.500000000000000000 9
1 1 MPC_THR_MAX 0.899999976158142090 9
1 1 MPC_THR_MIN 0.119999997317790985 9
1 1 MPC_TILTMAX_AIR 45.000000000000000000 9
1 1 MPC_TILTMAX_LND 12.000000000000000000 9
1 1 MPC_TKO_RAMP_T 0.400000005960464478 9
1 1 MPC_TKO_SPEED 1.500000000000000000 9
1 1 MPC_VELD_LP 5.000000000000000000 9
1 1 MPC_VEL_MANUAL 10.000000000000000000 9
1 1 MPC_XY_CRUISE 5.000000000000000000 9
1 1 MPC_XY_MAN_EXPO 0.000000000000000000 9
1 1 MPC_XY_P 0.949999988079071045 9
1 1 MPC_XY_VEL_D 0.009999999776482582 9
1 1 MPC_XY_VEL_I 0.019999999552965164 9
1 1 MPC_XY_VEL_MAX 12.000000000000000000 9
1 1 MPC_XY_VEL_P 0.090000003576278687 9
1 1 MPC_Z_MAN_EXPO 0.000000000000000000 9
1 1 MPC_Z_P 1.000000000000000000 9
1 1 MPC_Z_VEL_D 0.000000000000000000 9
1 1 MPC_Z_VEL_I 0.019999999552965164 9
1 1 MPC_Z_VEL_MAX_DN 1.000000000000000000 9
1 1 MPC_Z_VEL_MAX_UP 3.000000000000000000 9
1 1 MPC_Z_VEL_P 0.200000002980232239 9
1 1 NAV_ACC_RAD 2.000000000000000000 9
1 1 NAV_AH_ALT 600.000000000000000000 9
1 1 NAV_AH_LAT -265847810 6
1 1 NAV_AH_LON 1518423250 6
1 1 NAV_DLL_ACT 0 6
1 1 NAV_DLL_AH_T 120.000000000000000000 9
1 1 NAV_DLL_CHSK 0 6
1 1 NAV_DLL_CH_ALT 600.000000000000000000 9
1 1 NAV_DLL_CH_LAT -266072120 6
1 1 NAV_DLL_CH_LON 1518453890 6
1 1 NAV_DLL_CH_T 120.000000000000000000 9
1 1 NAV_DLL_N 2 6
1 1 NAV_FORCE_VT 1 6
1 1 NAV_FT_DST 8.000000000000000000 9
1 1 NAV_FT_FS 1 6
1 1 NAV_FT_RS 0.500000000000000000 9
1 1 NAV_FW_ALT_RAD 10.000000000000000000 9
1 1 NAV_GPSF_LT 0.000000000000000000 9
1 1 NAV_GPSF_P 0.000000000000000000 9
1 1 NAV_GPSF_R 15.000000000000000000 9
1 1 NAV_GPSF_TR 0.000000000000000000 9
1 1 NAV_LOITER_RAD 50.000000000000000000 9
1 1 NAV_MC_ALT_RAD 0.800000011920928955 9
1 1 NAV_MIN_FT_HT 8.000000000000000000 9
1 1 NAV_RCL_ACT 2 6
1 1 NAV_RCL_LT 120.000000000000000000 9
1 1 NAV_TRAFF_AVOID 1 6
1 1 PLD_BTOUT 5.000000000000000000 9
1 1 PLD_FAPPR_ALT 0.100000001490116119 9
1 1 PLD_HACC_RAD 0.200000002980232239 9
1 1 PLD_MAX_SRCH 3 6
1 1 PLD_SRCH_ALT 10.000000000000000000 9
1 1 PLD_SRCH_TOUT 10.000000000000000000 9
1 1 PWM_AUX_DISARMED 1500 6
1 1 PWM_AUX_MAX 2000 6
1 1 PWM_AUX_MIN 1000 6
1 1 PWM_AUX_REV1 0 6
1 1 PWM_AUX_REV2 0 6
1 1 PWM_AUX_REV3 0 6
1 1 PWM_AUX_REV4 0 6
1 1 PWM_AUX_REV5 0 6
1 1 PWM_AUX_REV6 0 6
1 1 PWM_AUX_TRIM1 0.000000000000000000 9
1 1 PWM_AUX_TRIM2 0.000000000000000000 9
1 1 PWM_AUX_TRIM3 0.000000000000000000 9
1 1 PWM_AUX_TRIM4 0.000000000000000000 9
1 1 PWM_AUX_TRIM5 0.000000000000000000 9
1 1 PWM_AUX_TRIM6 0.000000000000000000 9
1 1 PWM_DISARMED 900 6
1 1 PWM_MAIN_DIS1 -1 6
1 1 PWM_MAIN_DIS2 -1 6
1 1 PWM_MAIN_DIS3 -1 6
1 1 PWM_MAIN_DIS4 -1 6
1 1 PWM_MAIN_DIS5 -1 6
1 1 PWM_MAIN_DIS6 -1 6
1 1 PWM_MAIN_DIS7 -1 6
1 1 PWM_MAIN_DIS8 -1 6
1 1 PWM_MAX 1950 6
1 1 PWM_MIN 1075 6
1 1 PWM_RATE 400 6
1 1 RC10_DZ 0.000000000000000000 9
1 1 RC10_MAX 2000.000000000000000000 9
1 1 RC10_MIN 1000.000000000000000000 9
1 1 RC10_REV 1.000000000000000000 9
1 1 RC10_TRIM 1500.000000000000000000 9
1 1 RC11_DZ 0.000000000000000000 9
1 1 RC11_MAX 2000.000000000000000000 9
1 1 RC11_MIN 1000.000000000000000000 9
1 1 RC11_REV 1.000000000000000000 9
1 1 RC11_TRIM 1500.000000000000000000 9
1 1 RC12_DZ 0.000000000000000000 9
1 1 RC12_MAX 2000.000000000000000000 9
1 1 RC12_MIN 1000.000000000000000000 9
1 1 RC12_REV 1.000000000000000000 9
1 1 RC12_TRIM 1500.000000000000000000 9
1 1 RC13_DZ 0.000000000000000000 9
1 1 RC13_MAX 2000.000000000000000000 9
1 1 RC13_MIN 1000.000000000000000000 9
1 1 RC13_REV 1.000000000000000000 9
1 1 RC13_TRIM 1500.000000000000000000 9
1 1 RC14_DZ 0.000000000000000000 9
1 1 RC14_MAX 2000.000000000000000000 9
1 1 RC14_MIN 1000.000000000000000000 9
1 1 RC14_REV 1.000000000000000000 9
1 1 RC14_TRIM 1500.000000000000000000 9
1 1 RC15_DZ 0.000000000000000000 9
1 1 RC15_MAX 2000.000000000000000000 9
1 1 RC15_MIN 1000.000000000000000000 9
1 1 RC15_REV 1.000000000000000000 9
1 1 RC15_TRIM 1500.000000000000000000 9
1 1 RC16_DZ 0.000000000000000000 9
1 1 RC16_MAX 2000.000000000000000000 9
1 1 RC16_MIN 1000.000000000000000000 9
1 1 RC16_REV 1.000000000000000000 9
1 1 RC16_TRIM 1500.000000000000000000 9
1 1 RC17_DZ 0.000000000000000000 9
1 1 RC17_MAX 2000.000000000000000000 9
1 1 RC17_MIN 1000.000000000000000000 9
1 1 RC17_REV 1.000000000000000000 9
1 1 RC17_TRIM 1500.000000000000000000 9
1 1 RC18_DZ 0.000000000000000000 9
1 1 RC18_MAX 2000.000000000000000000 9
1 1 RC18_MIN 1000.000000000000000000 9
1 1 RC18_REV 1.000000000000000000 9
1 1 RC18_TRIM 1500.000000000000000000 9
1 1 RC1_DZ 10.000000000000000000 9
1 1 RC1_MAX 2000.000000000000000000 9
1 1 RC1_MIN 1000.000000000000000000 9
1 1 RC1_REV 1.000000000000000000 9
1 1 RC1_TRIM 1494.000000000000000000 9
1 1 RC2_DZ 10.000000000000000000 9
1 1 RC2_MAX 2001.000000000000000000 9
1 1 RC2_MIN 1000.000000000000000000 9
1 1 RC2_REV 1.000000000000000000 9
1 1 RC2_TRIM 1499.000000000000000000 9
1 1 RC3_DZ 10.000000000000000000 9
1 1 RC3_MAX 2000.000000000000000000 9
1 1 RC3_MIN 1000.000000000000000000 9
1 1 RC3_REV 1.000000000000000000 9
1 1 RC3_TRIM 1000.000000000000000000 9
1 1 RC4_DZ 10.000000000000000000 9
1 1 RC4_MAX 2001.000000000000000000 9
1 1 RC4_MIN 1000.000000000000000000 9
1 1 RC4_REV 1.000000000000000000 9
1 1 RC4_TRIM 1500.000000000000000000 9
1 1 RC5_DZ 10.000000000000000000 9
1 1 RC5_MAX 2001.000000000000000000 9
1 1 RC5_MIN 1000.000000000000000000 9
1 1 RC5_REV 1.000000000000000000 9
1 1 RC5_TRIM 1500.000000000000000000 9
1 1 RC6_DZ 10.000000000000000000 9
1 1 RC6_MAX 2000.000000000000000000 9
1 1 RC6_MIN 1000.000000000000000000 9
1 1 RC6_REV 1.000000000000000000 9
1 1 RC6_TRIM 1500.000000000000000000 9
1 1 RC7_DZ 10.000000000000000000 9
1 1 RC7_MAX 2000.000000000000000000 9
1 1 RC7_MIN 1000.000000000000000000 9
1 1 RC7_REV 1.000000000000000000 9
1 1 RC7_TRIM 1500.000000000000000000 9
1 1 RC8_DZ 10.000000000000000000 9
1 1 RC8_MAX 2000.000000000000000000 9
1 1 RC8_MIN 1000.000000000000000000 9
1 1 RC8_REV 1.000000000000000000 9
1 1 RC8_TRIM 1500.000000000000000000 9
1 1 RC9_DZ 0.000000000000000000 9
1 1 RC9_MAX 2000.000000000000000000 9
1 1 RC9_MIN 1000.000000000000000000 9
1 1 RC9_REV 1.000000000000000000 9
1 1 RC9_TRIM 1500.000000000000000000 9
1 1 RC_ACRO_TH 0.000000000000000000 9
1 1 RC_ARMSWITCH_TH 0.250000000000000000 9
1 1 RC_ASSIST_TH 0.451886504888534546 9
1 1 RC_AUTO_TH 0.666666686534881592 9
1 1 RC_CHAN_CNT 8 6
1 1 RC_FAILS_THR 0 6
1 1 RC_FLT_CUTOFF 10.000000000000000000 9
1 1 RC_FLT_SMP_RATE 50.000000000000000000 9
1 1 RC_GEAR_TH 0.250000000000000000 9
1 1 RC_KILLSWITCH_TH 0.250000000000000000 9
1 1 RC_LOITER_TH 0.000000000000000000 9
1 1 RC_MAN_TH 0.500000000000000000 9
1 1 RC_MAP_ACRO_SW 0 6
1 1 RC_MAP_ARM_SW 0 6
1 1 RC_MAP_AUX1 6 6
1 1 RC_MAP_AUX2 7 6
1 1 RC_MAP_AUX3 0 6
1 1 RC_MAP_AUX4 0 6
1 1 RC_MAP_AUX5 0 6
1 1 RC_MAP_FAILSAFE 0 6
1 1 RC_MAP_FLAPS 0 6
1 1 RC_MAP_FLTMODE 0 6
1 1 RC_MAP_GEAR_SW 0 6
1 1 RC_MAP_KILL_SW 0 6
1 1 RC_MAP_LOITER_SW 0 6
1 1 RC_MAP_MAN_SW 0 6
1 1 RC_MAP_MODE_SW 5 6
1 1 RC_MAP_OFFB_SW 0 6
1 1 RC_MAP_PARAM1 0 6
1 1 RC_MAP_PARAM2 0 6
1 1 RC_MAP_PARAM3 0 6
1 1 RC_MAP_PITCH 2 6
1 1 RC_MAP_POSCTL_SW 0 6
1 1 RC_MAP_RATT_SW 0 6
1 1 RC_MAP_RETURN_SW 0 6
1 1 RC_MAP_ROLL 1 6
1 1 RC_MAP_STAB_SW 0 6
1 1 RC_MAP_THROTTLE 3 6
1 1 RC_MAP_TRANS_SW 0 6
1 1 RC_MAP_YAW 4 6
1 1 RC_OFFB_TH 0.000000000000000000 9
1 1 RC_POSCTL_TH 0.000000000000000000 9
1 1 RC_RATT_TH 0.500000000000000000 9
1 1 RC_RETURN_TH 0.000000000000000000 9
1 1 RC_STAB_TH 0.500000000000000000 9
1 1 RC_TRANS_TH 0.250000000000000000 9
1 1 RTL_DESCEND_ALT 10.000000000000000000 9
1 1 RTL_LAND_DELAY 0.000000000000000000 9
1 1 RTL_LAND_TYPE 0 6
1 1 RTL_MIN_DIST 5.000000000000000000 9
1 1 RTL_RETURN_ALT 30.000000000000000000 9
1 1 SDLOG_DIRS_MAX 0 6
1 1 SDLOG_MODE 0 6
1 1 SDLOG_PROFILE 3 6
1 1 SDLOG_UTC_OFFSET 0 6
1 1 SENS_BARO_QNH 1013.250000000000000000 9
1 1 SENS_BOARD_ROT 0 6
1 1 SENS_BOARD_X_OFF 1.676517486572265625 9
1 1 SENS_BOARD_Y_OFF 0.552951276302337646 9
1 1 SENS_BOARD_Z_OFF 0.000000000000000000 9
1 1 SENS_DPRES_OFF 0.000000000000000000 9
1 1 SENS_EN_LL40LS 0 6
1 1 SENS_EN_MB12XX 0 6
1 1 SENS_EN_SF0X 0 6
1 1 SENS_EN_SF1XX 0 6
1 1 SENS_EN_TFMINI 0 6
1 1 SENS_EN_TRANGER 0 6
1 1 SENS_FLOW_MINRNG 0.699999988079071045 9
1 1 SYS_AUTOCONFIG 0 6
1 1 SYS_AUTOSTART 4001 6
1 1 SYS_CAL_ACCEL 0 6
1 1 SYS_CAL_BARO 0 6
1 1 SYS_CAL_GYRO 0 6
1 1 SYS_CAL_TDEL 24 6
1 1 SYS_CAL_TMAX 10 6
1 1 SYS_CAL_TMIN 5 6
1 1 SYS_COMPANION 157600 6
1 1 SYS_FMU_TASK 1 6
1 1 SYS_HITL 0 6
1 1 SYS_LOGGER 1 6
1 1 SYS_MC_EST_GROUP 2 6
1 1 SYS_PARAM_VER 1 6
1 1 SYS_RESTART_TYPE 2 6
1 1 SYS_STCK_EN 1 6
1 1 TC_A_ENABLE 0 6
1 1 TC_B_ENABLE 0 6
1 1 TC_G_ENABLE 0 6
1 1 THR_MDL_FAC 0.000000000000000000 9
1 1 TRIG_MODE 0 6
1 1 UAVCAN_ENABLE 0 6
1 1 VT_B_DEC_MSS 2.000000000000000000 9
1 1 VT_B_REV_DEL 0.000000000000000000 9
It is solved. I fixed a few basic setup and now is ready to fly.
