It is very sad to say that my Skywalker X8 flight got crashed.
Incident:
Hand Launched. Used only Throttle stick in FBWA.
Plane started to glide and suddenly it rolled left and crashed.
After crash I checked my Control surfaces and it’s perfectly configured.
I used FBWA mode and it worked.
After checking the logs I found that both Compass and Magnetometer got failed.
I’ve successfully did all the calibration and the plane got Armed after all.
My CG and weight balance was fine.
My analysis:
I’ve enabled AHRS_EKF_TYPE and EK2_ENABLE in mission planner and used parameter 2 and 1 respectively. I did my Mag calibration successfully. But I don’t know what happened really.
I attached my log file links. https://drive.google.com/open?id=1LZyPhObXW30uKauDdFdQc6oHD91hzYSa Hope someone can understand and can help me out of this problem.
