I am not sure if your goal is to fly without gps. But with gps you can push waypoints either when the vehicle is in flight or on the land and have it follow your gps waypoint in gazebo simulation.
This is how I do it. I got these code snippets from other posts and scrounging around documentation and code
for (int i = 0; i<allUAVWaypoints.size(); i++)
std::cout<<"Waypoint size = "<<allUAVWaypoints[i].waypoints.size() <<std::endl;
for(int k = 0; k < allUAVWaypoints[i].waypoints.size(); k++)
waypointPusher(wayPusher[i], pushClient[i], n,
allUAVWaypoints[i].waypoints[k].frame,
allUAVWaypoints[i].waypoints[k].command,
allUAVWaypoints[i].waypoints[k].isCurrent,
allUAVWaypoints[i].waypoints[k].isAutoContinue,
allUAVWaypoints[i].waypoints[k].param1,
allUAVWaypoints[i].waypoints[k].param2,
allUAVWaypoints[i].waypoints[k].param3,
allUAVWaypoints[i].waypoints[k].param4,
allUAVWaypoints[i].waypoints[k].lat,
allUAVWaypoints[i].waypoints[k].lon,
allUAVWaypoints[i].waypoints[k].alt,
allUAVWaypoints[i].serviceName);
I generated the waypoints via QGroundControl and saved them in a file and read them in. The service name to push to is
uav1/mavros/mission/push
Additionally, if you are doing GPS waypoint mission you will need to turn off a couple of parameters that won’t allow missions if there is no RC link or data link. For the exact names of the parameter you can look at my post
Not sure this is helpful to you. But I never got any help from others on this forum. You will at least have a reply now
