I’m trying to set attitude setpoint commands using micrortps. I have it all up and running, meaning the client receives the setpoint commands from the agent. I’m using a publisher through the listener. I can even see the attitude setpoints when I run listener vehicle_attitude_setpoint in the pxh console. But the commands aren’t being used by PX4, I can’t get into OFFBOARD mode. The only difference between my attitude setpoint commands through RTPS is that the timestamp is 0. I tried to incorporate the timestamp in my publisher cxx file, but it says it is not a member of the vehicle_attitude_setpoint class. Why wasn’t timestamp included with the vehicle attitude setpoint command? How can I incorporate the timestamp, and how do I get the correct one inside the rtps agent/listener?
Hi I am trying to use micrortps example to perform similar task. The agent app is able to receive some message but after some seconds the communication just stops. I am assuming you were able to establish a reliable communication. It will be helpful if you can share some details like,
- what device you used to send and receive uorb messages
- What was the baud rate
- did you use any sleep between iteration
- were the poll and update rate set to defaults.
- Did you use Nuttx for client and linux for agent and listener?
Thanks!
