Servos not at 1500us in manual mode
When setting up a flying wing using the TBS Caipirinha airframe preset in QGC the servos are not at zero trim level (1500us) for pitch in manual mode.
Logfile is here:
http://logs.uaventure.com/view/kiFw3qPAGjM2ajWxe5bux3
Anyone know why?
Cheers!
There’s an offset in that mixer. https://github.com/PX4/Firmware/blob/master/ROMFS/px4fmu_common/mixers/caipi.main.mix#L27
Thank you very much!
Why would it be an offset in the mixer? And how is the correct way of removing it? Do I really have to change the mixer directly to get the servos centered?
Cheers
you can try using the new PWM_MAIN/AUX_TRIMn parameters to recenter, but I’m not sure how that interacts with a mixer offset
IIRC, the parameters override the offset
