Hi , I am using DJI550 , and the battery parameters saved in are as follows.
Drone03
1 1 BAT_A_PER_V 15.391030311584472656 9
1 1 BAT_CAPACITY -1.000000000000000000 9
1 1 BAT_CNT_V_CURR 0.000805664050858468 9
1 1 BAT_CNT_V_VOLT 0.000805664050858468 9
1 1 BAT_CRIT_THR 0.070000000298023224 9
1 1 BAT_LOW_THR 0.150000005960464478 9
1 1 BAT_N_CELLS 4 6
1 1 BAT_R_INTERNAL -1.000000000000000000 9
1 1 BAT_SOURCE 0 6
1 1 BAT_V_CHARGED 4.000000000000000000 9
1 1 BAT_V_DIV 10.165575027465820312 9
1 1 BAT_V_EMPTY 3.400000095367431641 9
1 1 BAT_V_LOAD_DROP 0.300000011920928955 9
1 1 BAT_V_OFFS_CURR 0.000000000000000000 9
1 1 BAT_V_SCALE_IO 10000 6
The plots of the flight can be seen here
The problem, is that I connect two charged batteries, LiPo with 4 cells, and the FCU gives battery drainage warning too soon, sometimes, after a minute , sometimes, couple of seconds. When I connect this battery to other drone, the other drone considers it fully charged. Is there anything I can do to fix this situation?
