Is it possible to implement R/C channel passthrough to PWM outputs that aren’t in use on the selected airframe? My specific planned use case goes like this:
Pixracer
16ch SBUS R/C input (FrSky X4R-SB)
Quad airframe (PWM 5 and 6 unused)
Separate gimbal (Feiyutech Mini-3D) that takes PWM input for operating mode and camera pitch
What I would like to do is use PWM 5 and 6 outputs of the Pixracer to control mode and camera pitch on the gimbal, using two RC channels not mapped to any PX4 function. Essentially this makes the Pixracer additionally function like an SBUS-to-PWM decoder.
If it’s possible to make a configuration like this already, I’d much appreciate a hint where I need to look - a search of the existing documentation didn’t reveal much, though maybe I’m not thorough enough. If not, could such a feature be implemented?
I’m interested in doing something similar. I don’t have my pixracer yet, but have been looking at the settings in preparation.
So, here is a list of parameters: https://pixhawk.org/firmware/parameters#radio_calibration
and look at “RC_MAP_AUX#” and that might point you in the correct direction.
It mentions what the default function of the “aux” channels does, but I don’t know how to define an alternate function.
–edited to say I think I’m wrong, but will leave this just in case it helps… But I guess what I mentioned is assigning an RC channel to a different PIN that isn’t available on the pixracer, and not to one of the existing RC pins… I suppose we should wait for someone experienced to answer.
I need exactly the same setup as @olex mentioned. Could any PX4 developer give us any hint/advice, please? Pixracer does not have any AUX pins. Parameter RC_MAP_AUX# is related to physical AUX pin only but I could be wrong.
I see group 3 index 5 and 6, but I don’t understand how this maps to an output on either the pixracer or the pixfalcon. If this maps something to motor output 5 and 6 for quad x frames doesn’t appear to be working in the current stable release that qground control loaded onto my pixfalcon.
