Hello, all.
I heard that it is possible to generate the list of all tunable parameters in the XML form.
So, after I received v1.8.0 (stable) of px4, I tried to execute it. But, none of them does work.
Do you know how to generate it?
Here is the list of my trials
Trial 1
…Firmware/src/lib$ ./parameters/px_process_params.py --xml
File “./parameters/px_process_params.py”, line 200, in
main()
File “./parameters/px_process_params.py”, line 146, in main
if not scanner.ScanDir(args.src_path, parser):
File “/home/tgkim/uavfuzz/uavs/px4_recent/Firmware/src/lib/parameters/px4params/srcscanner.py”, line 20, in ScanDir
for filename in os.listdir(srcdir):
OSError: [Errno 2] No such file or directory: ‘…/src’
Trial 2
…Firmware/src$ ./lib/parameters/px_process_params.py --xml
Warning: no parameters found
File “./lib/parameters/px_process_params.py”, line 200, in
main()
File “./lib/parameters/px_process_params.py”, line 172, in main
os.path.join(cur_dir, args.inject_xml))
File “/usr/lib/python2.7/posixpath.py”, line 68, in join
if b.startswith(’/’):
AttributeError: ‘NoneType’ object has no attribute ‘startswith’
Other than them, I tried other options but none of them work.
They are the only error message variants that I saw.
Thank you
