QGroundControl Stable 3.4 released
High level release notes here: https://docs.qgroundcontrol.com/en/releases/release_notes.html. Builds available at http://qgroundcontrol.com, Google Play and iOS App Store.
  • Settings
    • Offline Maps
      • Center Tool allows you to specify a map location in lat/lon or UTM coordinates. Making it easier to get to the location you want to create an offline map for.
      • Ability to pre-download terrain heights for offline use.
    • Help Provides links to QGC user guide and forums.
  • Setup
    • Firmware Ability to flash either PX4 or ArduPilot Flow firmware.
    • PX4 Pro Firmware
      • Flight Modes Specify channels for all available transmitter switches.
      • Tuning: Advanced Initial implementation of vehicle PID tuning support. Note that this is a work in progress that will improve in 3.5 daily builds.
    • ArduPilot Firmware
      • Power/Safety Support for new multi-battery setup.
      • Trad Heli New setup page.
  • Plan
    • File Load/Save New model for Plan file loading which matches a standard File Load/Save/Save As user model.
    • Load KML Ability to load a KML file directly from the Sync menu. You will be prompted for what type of Pattern you want to create from the KML if needed.
    • Survey Better support for irregular shaped polygons.
    • Corridor Scan - Create a flight pattern which follows a poly-line. For example can be used to survey a road.
    • Fixed Wing Landing Pattern
      • Landing area visually represented in Plan.
      • Landing position/heading can be copied from Vehicle position/heading.
    • Terrain
    • Edit Position Set item position from vehicle position.
  • Fly
    • Pre-Flight Checklist You can turn this on from Settings. It provides a generic checklist to follow prior to flight. Expect more feature to appear for this in 3.5 daily builds.
    • Instrument Panel
      • Many new values available for display.
      • New Camera page which provides full camera control. Requires a camera which support new MavLink camera specification.
    • ArduPlane Much better support for guided commands including QuadPlane support.
    • High Latency Links Support for high latency links such as satelitte connections. Limits the traffic from QGC up to Vehicle on these links to reduce cost. Supports HIGH_LATENCY mavlink message. Supports failover back/forth from high latency to normal link with dual link setup.
Important Update: There is a bug in QGC 3.4 which can cause the altitudes in mission items to sent to the vehicle as 0 when the ui still shows a good value. The easiest way to reproduce this is to:
  • Add the first Takeoff item to a mission
  • Change the Takeoff item to a Waypoint
  • Add a new waypoint item
All subsequently added waypoint items will show in the UI with a reasonable altitude but will be sent to the vehicle as 0 height which can cause a crash.
Standard mission creation where you add the first item which is added as a Takeoff (leave it as Takeoff) and then add subsequent waypoints is working fine.
Issue details are here: https://github.com/mavlink/qgroundcontrol/issues/6823. A new 3.4.2 which fixes this will be available in a few hours.
QGC Stable 3.4.2 has been released which fixes the waypoint altitude bug.
Where to get the download link for MacOS latest version for qgroundcontrol?
https://docs.qgroundcontrol.com/master/en/getting_started/download_and_install.html#macOS
Good luck.
I downloaded this latest version but it shows V 0.0.0
Can you give me the correct download link for the latest QGC for Mac OS?
