QGroundcontrol "Detected 0 radio channels. To operate PX4 you need at least 5 channels"
Dear people
I do have a question about the pixhawk mini and Qgroundcontrol
I wan to calibrate the RC transmitter (Graupner mz-12) and the Receiver (Graupner hott, 2400) by means of Qgroundcontrol under ubuntu 16 over the Pixhawk mini.
According to the following link Redirecting to latest version of document (master)
  • I have connected ch6 from the graupner receiver to the RCIN on the pixhawk mini.
  • I have binded ch1 to ch 5 (transmitter and receiver), and set up to “ON” the RF transmit from ch1 to ch5 on the receiver. In other words, RF sett->rx = R06 (which means is binded) and RF->RF = ON. In every channel from 1-5 and channel 6 is set to “free”
  • Then on my Graupner mz-12 I went into the Telemetry->Settings & Data View menu, scroll to bottom where it says SUMD on ch6 and change to yes
When i click in the radio icon on QGroundcontrol
I always get "detected 0 radio channels. to operate px4 you need at least 5 channels
I upload some pictures of the setup.
Thank you very much and
I am looking forward to your replay. and thank you.
Good day,
Spektrum and DSM receivers must connect to a SPKT/DSM input of the pixhawk mini,
PPM-Sum and S.BUS receivers must connect directly to the RC ground, power and signal pins typically labeled RC or RCIN
PPM receivers that have an individual wire for each channel must connect to the RCIN channel via a PPM encoder like this one (PPM-Sum receivers use a single signal wire for all channels).
Hi there,
Thank you for your replay.
You gave me 3 cases.
  1. Spektrum and DSM receivers must connect to a SPKT/DSM input of the pixhawk mini,
  2. PPM-Sum and S.BUS receivers must connect directly to the RC ground, power and signal pins typically labeled RC or RCIN
  3. PPM receivers that have an individual wire for each channel must connect to the RCIN channel via a PPM encoder like this one (PPM-Sum receivers use a single signal wire for all channels).
Which one of the three cases is my case? And, how can I solve it.
Would you mind taking a look at this site
https://www.rcgroups.com/forums/showthread.php?2400871-Configuring-SUM-signal-in-a-Graupner-mz-18-24
It looks similar to my case, but i do not know what im doing wrong :slight_smile:
cheers :slight_smile:
Spektrum and DSM receivers must connect to a SPKT/DSM input of the pixhawk mini, with the appropriate cable, coz the rc in port is different in size.
Hi there
Would you mind explaining more according to my setup
I mean:
  • settings in the RC transmitter
  • which channel in the RC receiver
  • is there anything I need to set up in the QGroundcontrol
Cheers and thank you
Good day,
if you want use Spektrum and DSM receiver you must first wire it on SPKT/DSM port of the pixhawk mini
Good day,
do you have an schematic on how to wire SUMD from the hott 2400 graupner receiver and the SPKT/DSM port of the pixhawk mini?
Thank you
Its the same like the rc in port but the connector attached on the board is different
I have the same issue with mine. My setup is Pixhawk, Lemonrx plugged into Spektrum/PPM port. Receiver binds fine with my Spektrum DX6 by itself. When I try to bind through QGroundControl, bind fails in any of the three modes. With the rx bound, I get the message that 0 radio channels are detected. What do I do next?
From my experience, I’ve found it best to bind the satellite Rx first with a regular receiver first and test to make sure all outputs are working there. From that point, transfer the satellite Rx to the Pixhawk then do your RC calibration in QGC.
Good luck.
There is a massive hole in my knowledge. I am very new to the drone/quad world. All of my previous RC experience has been in sailboats, and they all use ‘standard’ configuration rx & servos. I have no experience with satellite Rxs. I think I understand that the satellite is bound through another rx with a PPM port. Do both have to be on board, or do I run with the satellite only on the quad after binding? Is there a tutorial somewhere I can read on this? Thanks for putting up with this overly-long post.
If you have the receiver and the satellite rx:
  • Bind the receiver with the satellite rx connected to it.
  • When binding is complete, unplug the satellite rx from the receiver and plug it into the SKPT/DSM port of the Pixhawk.
  • Mount the satellite rx as far as possible from other electrical/electronic components.In my case, I used a 3ft extension and mounted it on the vertical fin.
  • Connect the Pixhawk to QGC and calibrate
  • Depending on the airframe you chose during your initial setup, you can assign up to two RC channels to AUX1 and AUX2 ports of the Pixhawk. For example, you can use these channels control a camera gimbal.
If you have just the receiver only (bottom)
  • You’ll need a PPM encoder.
  • Bind the receiver to your Tx.
  • Plug the PPM encoder to the PWM ports of the receiver.
  • The other end plugs into the RCIN of the Pixhawk.
  • You’ll need to supply a separate 5v power to your receiver.
  • Connect it to QGC calibrate
Good luck.
LemonRX1
Hi rolly,
In your first case, after bind and unplug the satellite rx from the reveiver and plug into the DSM port of the Pixhawk, what should you do with the receiver?
After I plug the satellite rx into the DSM/SBUS RC port in Pixhawk 4, I can use QGoundControl to set the rx into bind mode again, but still I cannot calibrate the transmitter(no channel found, and no signal show on the screen of transmitter).
Right now I’m using AR8010T.
Thanks.
You don’t need the receiver anymore since your Satellite Rx is now your receiver.
Once you bind the satellite Rx with the main receiver, then plug the Satellite Rx to the FC, you don’t need to bind again since your Tx is already bound to it. You should be able to just go to the Radio tab and perform the calibration.
Maybe it lost its bind with the Tx when you tried to bind again in QGC. Rebind it using the main receiver and then just plugin to FC. Make sure the Tx is on before powering the FC. Once it’s powered up (via USB), confirm that the Satellite Rx LED is solid (not blinking) to indicated it’s bound/connected to the Tx. Calibration should work at that point. If the Satellite Rx is blinking, check to make sure the wiring is correct in reference to the pins of the FC.
Good luck.
Thanks for reply.
I did what you said and the LED are solid on Satellite Rx, but QGC still cannot find any channel.
Can you confirm the wiring sequence of the Rx in the DSM/SBUS RC as follows:
  • Pin# 2 > Signal wire of the Satellite Rx
  • Pin# 4 > +3.3 V
  • Pin# 5 > Ground
Good luck.
By the way, you didn’t say what Tx you’re using; is it a Spektrum or Taranis? If it’s Taranis, I believe you have to modify and extend the range. On my QX7, I’ve had to set it up with 22.5ms and -400u.
Good luck.
I bought the Holybro QAV250 kit with the Pixhawk 4 mini. It also came with the R-XSR reciever. I hooked the reciever up to the RC IN port and binded it with the a FrSky X-Lite successfully. When I enter QGroundcontrol, I get the same message as mentioned above. PLEASE advise!
just check the wires… must be like in the pic I will attach ee0fb96609a47b6a370f2cbd642e26a4146b0064
Thank you Dave84. The connector that came with the build has four wires. Not three. Any advice?
PAKman
