I have Sony PS4 DualShock 4 joystick, which have 6 proportional controllers. The main 4 axes work correctly (x, y, z, r).
I would like to get working the last two proportional inputs. In QGC in part ‘Joystick’ I can see that it reads input from the joystick. When I move with this controllers, in axis monitor
I can see that it is axis 2 and 5.
Then I set in radio panel in QGC AUX1 Passthrought RC channel
to Channel 2
(or 5). But aircraft has no response. And there is no change in mavlink data in (RC_channels). The same behavior is when I set it as flaps input.
Do you have any suggestion how to get work all analog channels from USB joystick?
Thank you!
