QGC Master 6. April - Doesn't Launch on OSX
Having problem lauching the qgc master on my mac osx 10.10.5
`> Process: qgroundcontrol [818]
Path: /Applications/qgroundcontrol.app/Contents/MacOS/qgroundcontrol
Identifier: org.qgroundcontrol.qgroundcontrol
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: qgroundcontrol [818]
User ID: 501
Date/Time: 2016-04-06 20:45:01.138 +0200
OS Version: Mac OS X 10.10.5 (14F1713)
Report Version: 11
Anonymous UUID: 84E661FA-32AC-66B2-8843-7B182F64D722
Time Awake Since Boot: 1400 seconds
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /Library/Frameworks/GStreamer.framework/Versions/1.0/lib/GStreamer
Referenced from: /Applications/qgroundcontrol.app/Contents/MacOS/qgroundcontrol
Reason: image not found
Binary Images:
0x7fff6ea7b000 - 0x7fff6eab1887 dyld (353.2.3) /usr/lib/dyld
0x7fff8aedd000 - 0x7fff8b275ff7 com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8d670000 - 0x7fff8d6e2fff com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff9235c000 - 0x7fff9235cfff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
Model: MacBookPro6,2, BootROM MBP61.0057.B11, 2 processors, Intel Core i7, 2.66 GHz, 8 GB, SMC 1.58f17
Graphics: Intel HD Graphics, Intel HD Graphics, Built-In
Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3032302E4130304C4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3032302E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.3.6f3 16238, 3 services, 18 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS725050A9A362, 500.11 GB
Serial ATA Device: HL-DT-ST DVDRW GS23N
USB Device: Hub
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Internal Memory Card Reader
USB Device: Hub
USB Device: IR Receiver
USB Device: Built-in iSight
Thunderbolt Bus:
Lauching the Master Version from yesterday works fine
Anyone?
Hat sich gelöst. Eine neue Library muss installiert werden.
http://gstreamer.freedesktop.org/data/pkg/osx/1.5.2/gstreamer-1.0-1.5.2-x86_64.pkg
There was about a weeks worth of daily builds there this was broken. Fixed now.
