PX4IO problem on Pixhawk 2.1
I’m using a pixhawk 2.1 flashed with Firmware 1.5.3. I first noticed that the RC inputs were not recognized by the board (I’m using a spektrum receiver connected into the spkt/dsm port. I’m sure that the RC and the receiver are porperly bound) but then I looked at the NSH console to see messages while booting and I now think that the entire px4io module is not working properly. I’m attaching the log of messages I got. Does anyone have a clue how to solve this issue?
sercon: Registering CDC/ACM serial driver
sercon: Successfully registered the CDC/ACM serial driver
WARN [param] selected parameter default file /fs/mtd_params
WARN [rgbled] no RGB led on bus #2
WARN [blinkm] I2C init failed
WARN [blinkm] init failed
WARN [px4io] check CRC failed: -22
INFO [px4io] default PWM output device
[PX4IO] using firmware from /etc/extras/px4io-v2.bin
[PX4IO] bad sync 0xff,0xff
[PX4IO] bootloader not responding
INFO [dataman] Power on restart, data manager file ‘/fs/microsd/dataman’ size is 47640 bytes
MS5611_SPI on SPI bus 4 at 2 (20000 KHz)
MS5611_SPI on SPI bus 1 at 3 (20000 KHz)
WARN [bst] no devices found
INFO [ver] match: PX4FMU_V2
HMC5883_I2C on I2C bus 1 at 0x1e (bus: 100 KHz, max: 400 KHz)
LIS3MDL bad ID: 3cWARN [lis3mdl] no device on bus 2
WARN [hmc5883] no device on bus 1
WARN [mpu6000] no device on bus 3
WARN [mpu6000] no device on bus 4
MPU9250 on SPI bus 4 at 1 (1000 KHz)
L3GD20 on SPI bus 4 at 4 (11000 KHz)
LSM303D on SPI bus 4 at 3 (11000 KHz)
MPU9250 on SPI bus 1 at 4 (1000 KHz)
HMC5883_SPI on SPI bus 1 at 5 (11000 KHz)
WARN [hmc5883] no device on bus 3
ERROR [meas_airspeed] no MS4525 airspeed sensor connected
ERROR [ets_airspeed] no ETS airspeed sensor connected
SF1XX disabled.
ERROR [sf1xx] driver start failed
WARN [commander] No RGB LED found at /dev/rgbled0
INFO [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS1 @ 57600B
INFO [mavlink] mode: OSD, data rate: 1000 B/s on /dev/ttyS2 @ 57600B
px4flow [208:100]
WARN [px4flow] scanning I2C buses for device…
INFO [mavlink] mode: Config, data rate: 800000 B/s on /dev/ttyACM0 @ 57600B
ERROR [mixer] can’t open /dev/pwm_output0
ERROR [mixer] failed to load mixer
ERROR [init] Error loading mixer: /etc/mixers/quad_+.main.mix
INFO [lib__ecl] EKF IMU buffer length = 21
INFO [lib__ecl] EKF observation buffer length = 16
NuttShell (NSH)
nsh> WARN [mavlink] Disabling hardware flow control
INFO [lib__ecl] EKF using pressure height - commencing alignment
WARN [commander_tests] Not ready to fly: Sensors not set up correctly
INFO [lib__ecl] EKF alignment complete
I’ve seen this a couple of times on Pixhawk 1. Usually re-flashing helps.
It often happens to me if IO is updated and for some reason the startup script fails to flash it. Just run
px4io forceupdate 14662 /etc/extras/px4io-v2.bin
in console and it flash the IO.
Thank you for answering, I tried just now to run ‘px4io forceupdate 14662 /etc/extras/px4io-v2.bin’ in console but I got the same result.
nsh> px4io forceupdate 14662 /etc/extras/px4io-v2.bin
WARN [px4io] px4io is not started, still attempting upgrade
nsh>
Any other ideas?
Do you have sufficient power? How are you powering your pixhawk? Make sure your main servo power rail has stable 5V.
Hi all,
I am getting same problem. This is the output of Pixhawk2.1 console:
nsh: blinkm: command not found
WARN [hmc5883] no device on bus 2
read_reg failWARN [lis3mdl] no device on bus 2
nsh: sf1xx: command not found
INFO [sensors] Baro sensor switch from #-1
px4flow [204:100]
ERROR [init] Error loading mixer: /etc/mixers/quad_x.main.mix
NuttShell (NSH)
nsh> INFO [lib__ecl] EKF using pressure height - commencing alignment
WARN [commander] Not ready to fly: Sensors not set up correctly
Does that indicate that the IO board fried??
Please advise!
Apply enough power to all the rails and execute this in console:
Please try the suggestion of vvid first, and if that doesn’t work… try loading Ardupilot, see if it works, then Reload PX4.
refer to this: https://pixhawk.org/users/flash_px4io
If you still have an older firmware on your PX4IO, auto-updating might fail after you flashed the latest PX4 firmware on your FMU. In this case, hold down the safety switch while powering up the system. PX4IO will then boot into bootloader mode which allows the FMU to properly update its firmware. You only need to do this once. Following upgrades of the PX4 firmware will successfully perform an auto-update again.
Hi, I know this is old but I am wondering if you found a way to solve your problem, I have similar issues
