Hi! My issue is with latest build (maybe with previous builds as well not tested though). I’m using pixhawk 4. And tested with 2 different px4flow sensors (one with sonar and other without).
Connecting px4flow sensors to QGC directly shows they are working well and gives good quality for my floor surface (above 250).
As I integrate one of them into the drone I see only temperature values changing in OPTICAL_FLOW_RAD as well as distance for the model with sonar and time values. All other values are zeroes (integration_time_us, integrated_{x,y,{x,y,z}gyro}). Even sensor_id is zero. While when I connect px4flow directly to QGC I see sensor_id is not zero.
Not only MAVLink shows those values. Reading uORB messages with
listener optical_flow
gives same results.
Btw I’m using additional LidarLite sensor for distance measurement in PWM mode. It provides correct readings which are observed over MAVLink or directly reading uORB messages with listener.
I’m trying to run without GPS.
My config values are:
param set SENS_FLOW_MINHGT 0.3
param set SENS_FLOW_ROT 4
param set EKF2_AID_MASK 2
param set EKF2_RNG_AID 1
param set EKF2_HGT_MODE 2
param set SENS_EN_LL40LS 1
