I am using px4flow sensor in Pixhawk4.
When I am using in stable firmware 1.8.2 it’s not showing any distance for distance sensor and any data through MAVLink Inspector related to px4flow sensor.
When I am using master firmware it’s showing all the data from px4flow sensor. I am using I2C port.
Although px4flow working fine with direct USB with QGroundControl.
Can anybody help me to use px4flow sensor with stable firmware?
Hi I’d got one and would like to test it, but cannot locate a Windows 10 driver to configure with MP or QGC . Do you have one you could share? Once I get it going I will share my results. Thx, Jack
I have a Win 10 desktop and a Win 10 laptop. The desktop COM port driver for the camera doesn’t work, but the laptop connects straight-away. There is a slight difference in the driver name. The camera worked fine with Mission Planner on the laptop.
The px4flow doesn’t work with the 1.8.2 stable release. No data for optical flow show in QGC.
Works fine with the master firmware and also through USB.
