I just updated the firmware on both pixhawk and PX4flow.
But I am not able to enable the PX4_Flow neither to get PX4Flow messages from QGC->Analyse tools.
Shouldnât there be a SENS_EN parameter for the PX4Flow as well ?
Thanks in advance,
Best
Nicolas
February 10, 2017, 6:11pm
2
The Pixhawk autostarts the PX4FLOW driver, no configuration necessary:
#!/bin/sh
# Un comment and use set +e to ignore and set -e to enable 'exit on error control'
set +e
# Un comment the line below to help debug scripts by printing a trace of the script commands
#set -x
# PX4FMU startup script.
# NOTE: environment variable references:
# If the dollar sign ('$') is followed by a left bracket ('{') then the
# variable name is terminated with the right bracket character ('}').
# Otherwise, the variable name goes to the end of the argument.
# NOTE: COMMENT LINES ARE REMOVED BEFORE STORED IN ROMFS.
# Set default paramter values.
# Do not add intra word spaces
# it wastes flash
set AUX_MODE pwm
set DATAMAN_OPT ""
set FAILSAFE none
set FAILSAFE_AUX none
set FCONFIG /fs/microsd/etc/config.txt
set FEXTRAS /fs/microsd/etc/extras.txt
set FMU_ARGS ""
set FMU_MODE pwm
set FRC /fs/microsd/etc/rc.txt
set IO_PRESENT no
set IOFW "/etc/extras/px4_io-v2_default.bin"
set IO_PRESENT no
set LOG_FILE /fs/microsd/bootlog.txt
set LOGGER_ARGS ""
set LOGGER_BUF 14
set MAV_TYPE none
set MIXER none
set MIXER_AUX none
set MIXER_FILE none
set MK_MODE none
set MKBLCTRL_ARG ""
set OUTPUT_MODE none
set PARAM_FILE /fs/microsd/params
set PWM_AUX_DISARMED p:PWM_AUX_DISARMED
set PWM_AUX_MAX p:PWM_AUX_MAX
set PWM_AUX_MIN p:PWM_AUX_MIN
set PWM_AUX_OUT none
set PWM_AUX_RATE p:PWM_AUX_RATE
set PWM_DISARMED p:PWM_DISARMED
set PWM_MAX p:PWM_MAX
set PWM_MIN p:PWM_MIN
set PWM_OUT none
set PWM_RATE p:PWM_RATE
set SDCARD_MIXERS_PATH /fs/microsd/etc/mixers
set USE_IO no
set VEHICLE_TYPE none
# Airframe parameter versioning: airframe maintainers can set this in the
# airframe startup script, and then increase it by one whenever an airframe
# parameter is updated - it will ensure that these parameters will be updated
# when the firmware is flashed.
set PARAM_DEFAULTS_VER 1
# Mount the procfs.
mount -t procfs /proc
# Start CDC/ACM serial driver.
sercon
# Print full system version.
ver all
# Start the ORB (first app to start)
# tone_alarm and tune_control
# is dependent.
uorb start
# Try to mount the microSD card.
# REBOOTWORK this needs to start after the flight control loop.
if mount -t vfat /dev/mmcsd0 /fs/microsd
then
if hardfault_log check
then
# Error tune.
tune_control play -t 2
if hardfault_log commit
then
hardfault_log reset
fi
else
# Play the startup tune.
tune_control play -t 1
fi
else
# tune SD_INIT
tune_control play -t 16
if mkfatfs /dev/mmcsd0
then
then
echo "INFO [init] card formatted"
else
tune_control play -t 17
echo "ERROR [init] format failed"
set LOG_FILE /dev/null
fi
else
fi
fi
# AEROCORE2 shouldn't have an sd card and CF2 may optionally have an sd card.
if ! ver hwcmp BITCRAZE_CRAZYFLIE GUMSTIX_AEROCORE2
then
# Run no SD alarm.
if [ $LOG_FILE = /dev/null ]
then
# tune Make FS MBAGP
fi
fi
# Look for an init script on the microSD card.
# Disable autostart if the script found.
if [ -f $FRC ]
then
sh $FRC
else
# Set the parameter file if mtd starts successfully.
if mtd start
then
set PARAM_FILE /fs/mtd_params
fi
# Load parameters.
param select $PARAM_FILE
if ! param load
then
param reset
fi
# Set AUTOCNF flag to use it in AUTOSTART scripts.
if param compare SYS_AUTOCONFIG 1
then
# Wipe out params except RC*, flight modes, total flight time, accel cal, gyro cal
param reset_nostart RC* COM_FLTMODE* LND_FLIGHT_T_* TC_* CAL_ACC* CAL_GYRO*
set AUTOCNF yes
else
if param compare SYS_AUTOCONFIG 2
then
set AUTOCNF yes
else
set AUTOCNF no
fi
fi
# Optional board defaults: rc.board_defaults
set BOARD_RC_DEFAULTS /etc/init.d/rc.board_defaults
if [ -f $BOARD_RC_DEFAULTS ]
then
echo "Board defaults: ${BOARD_RC_DEFAULTS}"
sh $BOARD_RC_DEFAULTS
fi
unset BOARD_RC_DEFAULTS
# Waypoint storage.
# REBOOTWORK this needs to start in parallel.
dataman start $DATAMAN_OPT
# Start the socket communication send_event handler.
send_event start
# Start the resource load monitor.
load_mon start
# Start system state indicator.
rgbled start
rgbled_ncp5623c start
rgbled_pwm start
if blinkm start
then
blinkm systemstate
fi
# Start the tone_alarm driver.
# Needs to be started after the parameters are loaded (for CBRK_BUZZER).
# Note that this will still play the already published startup tone.
tone_alarm start
if param compare SYS_FMU_TASK 1
then
set FMU_ARGS "-t"
fi
# Set parameters and env variables for selected AUTOSTART.
if ! param compare SYS_AUTOSTART 0
then
sh /etc/init.d/rc.autostart
fi
# Override parameters from user configuration file.
if [ -f $FCONFIG ]
then
echo "Custom: ${FCONFIG}"
sh $FCONFIG
fi
# If autoconfig parameter was set, reset it and save parameters.
if [ $AUTOCNF = yes ]
then
param set SYS_AUTOCONFIG 0
fi
# Check if PX4IO present and update firmware if needed.
# Assumption IOFW set to firmware file and IO_PRESENT = no
if [ -f $IOFW ]
then
# Check for the mini using build with px4io fw file
# but not a px4IO
if ver hwtypecmp V540
then
param set SYS_USE_IO 0
else
if px4io checkcrc ${IOFW}
then
set IO_PRESENT yes
else
# tune Program PX4IO
tune_control play -t 18
if px4io start
then
# Try to safety px4 io so motor outputs don't go crazy.
if ! px4io safety_on
then
# px4io did not respond to the safety command.
px4io stop
fi
fi
if px4io forceupdate 14662 ${IOFW}
then
usleep 10000
tune_control stop
then
echo "PX4IO CRC OK after updating" >> $LOG_FILE
#tune MLL8CDE Program PX4IO success
tune_control play -t 19
set IO_PRESENT yes
fi
fi
if [ $IO_PRESENT = no ]
then
echo "PX4IO update failed" >> $LOG_FILE
# Error tune.
tune_control play -t 20
fi
fi
fi
fi
# Set USE_IO flag.
if param compare SYS_USE_IO 1
then
set USE_IO yes
fi
if [ $USE_IO = yes -a $IO_PRESENT = no ]
then
echo "PX4IO not found" >> $LOG_FILE
# Error tune.
fi
if [ $IO_PRESENT = no -o $USE_IO = no ]
then
rc_input start
fi
# Sensors System (start before Commander so Preflight checks are properly run).
# Commander needs to be this early for in-air-restarts.
if param greater SYS_HITL 0
then
set OUTPUT_MODE hil
sensors start -h
commander start --hil
# disable GPS
param set GPS_1_CONFIG 0
# start the simulator in hardware if needed
if param compare SYS_HITL 2
then
sih start
fi
else
# board sensors: rc.sensors
set BOARD_RC_SENSORS /etc/init.d/rc.board_sensors
if [ -f $BOARD_RC_SENSORS ]
then
echo "Board sensors: ${BOARD_RC_SENSORS}"
sh $BOARD_RC_SENSORS
fi
unset BOARD_RC_SENSORS
sh /etc/init.d/rc.sensors
commander start
fi
# Sensors on the PWM interface bank.
if param compare SENS_EN_LL40LS 1
then
# Clear pins 5 and 6.
set FMU_MODE pwm4
set AUX_MODE pwm4
fi
if param greater TRIG_MODE 0
then
# We ONLY support trigger on pins 5 and 6 when simultanously using AUX for actuator output.
if param compare TRIG_PINS 56
then
# clear pins 5 and 6
set FMU_MODE pwm4
set AUX_MODE pwm4
else
set FMU_MODE none
set AUX_MODE none
fi
camera_trigger start
camera_feedback start
fi
# Check if UAVCAN is enabled, default to it for ESCs.
if param greater UAVCAN_ENABLE 0
then
# Start core UAVCAN module.
if uavcan start
then
if param greater UAVCAN_ENABLE 1
then
# Start UAVCAN firmware update server and dynamic node ID allocation server.
uavcan start fw
if param greater UAVCAN_ENABLE 2
then
set OUTPUT_MODE uavcan_esc
fi
fi
else
# Error tune.
fi
fi
# Start mavlink streams that are not configurable (e.g. on USB).
sh /etc/init.d/rc.mavlink
# Start UART/Serial device drivers.
# Note: rc.serial is auto-generated from Tools/serial/generate_config.py
sh /etc/init.d/rc.serial
# Configure vehicle type specific parameters.
# Note: rc.vehicle_setup is the entry point for rc.interface,
# rc.fw_apps, rc.mc_apps, rc.ugv_apps, and rc.vtol_apps.
sh /etc/init.d/rc.vehicle_setup
# Camera capture driver
if param greater CAM_CAP_FBACK 0
then
if camera_capture start
then
camera_capture on
fi
fi
# Start the navigator.
navigator start
# Start the standalone wind estimator.
if param compare WEST_EN 1
then
wind_estimator start
fi
# Start a thermal calibration if required.
sh /etc/init.d/rc.thermal_cal
# Start vmount to control mounts such as gimbals, disabled by default.
if ! param compare MNT_MODE_IN -1
then
vmount start
fi
# Check for flow sensor, launched as a background task to scan
px4flow start &
# Optional board supplied extras: rc.board_extras
set BOARD_RC_EXTRAS /etc/init.d/rc.board_extras
if [ -f $BOARD_RC_EXTRAS ]
then
echo "Board extras: ${BOARD_RC_EXTRAS}"
sh $BOARD_RC_EXTRAS
fi
unset BOARD_RC_EXTRAS
# Start any custom addons from the sdcard.
if [ -f $FEXTRAS ]
then
echo "Addons script: ${FEXTRAS}"
sh $FEXTRAS
fi
# Start the logger.
sh /etc/init.d/rc.logging
if ! param compare SYS_PARAM_VER ${PARAM_DEFAULTS_VER}
then
echo "Switched to different parameter version. Resetting parameters."
param set SYS_PARAM_VER ${PARAM_DEFAULTS_VER}
param set SYS_AUTOCONFIG 2
param save
reboot
fi
# End of autostart.
fi
# Unset all script parameters to free RAM.
unset AUTOCNF
unset AUX_MODE
unset DATAMAN_OPT
unset FAILSAFE
unset FAILSAFE_AUX
unset FCONFIG
unset FEXTRAS
unset FMU_ARGS
unset FMU_MODE
unset FRC
unset IO_PRESENT
unset IOFW
unset LOG_FILE
unset LOGGER_ARGS
unset LOGGER_BUF
unset MAV_TYPE
unset MIXER
unset MIXER_AUX
unset MIXER_FILE
unset MK_MODE
unset MKBLCTRL_ARG
unset OUTPUT_MODE
unset PARAM_DEFAULTS_VER
unset PARAM_FILE
unset PWM_AUX_DISARMED
unset PWM_AUX_MAX
unset PWM_AUX_MIN
unset PWM_AUX_OUT
unset PWM_AUX_RATE
unset PWM_DISARMED
unset PWM_MAX
unset PWM_MIN
unset PWM_OUT
unset PWM_RATE
unset SDCARD_MIXERS_PATH
unset USE_IO
unset VEHICLE_TYPE
# Boot is complete, inform MAVLink app(s) that the system is now fully up and running.
mavlink boot_complete
This file has been truncated. show original
Have you looked at the console ouput of your Pixhawk? Is px4flow
starting properly?
Thanks for you answer Nicolas.
I finally manage to get an FTDI and could play with nutshell.
While typing âpx4flow infoâ I see âError [px4flow] not runningâ
while typing âpx4flow startâ I see that it is scanning i2c bus.
But then nothing happen.
if I run again px4flow info I see that the driver is still not running.
I will cross check the cabling again in case.
I will let you know.
Cheers
Cabling is correct.
When I boot I got this
nsh> sercon: Registering CDC/ACM serial driver
sercon: Successfully registered the CDC/ACM serial driver
WARN [param] selected parameter default file /fs/mtd_params
rgbled on I2C bus 2 at 0x55 (bus: 100 KHz, max: 100 KHz)
WARN [px4io] CRCs match
INFO [dataman] Power on restart, data manager file â/fs/microsd/datamanâ size is 47640 bytes
MS5611_SPI on SPI bus 4 at 2 (20000 KHz)
WARN [ms5611] no device on bus 4
ERROR [ms5611] driver start failed
MS5611_SPI on SPI bus 1 at 3 (20000 KHz)
WARN [bst] no devices found
INFO [ver] match: PX4FMU_V2
WARN [hmc5883] no device on bus 2
read_reg failWARN [lis3mdl] no device on bus 2
WARN [hmc5883] no device on bus 1
WARN [mpu6000] no device on bus 3
WARN [mpu6000] no device on bus 4
WARN [mpu9250] no device on bus 4
MPU6000 on SPI bus 1 at 4 (1000 KHz)
WARN [mpu9250] no device on bus 3
L3GD20 on SPI bus 1 at 1 (11000 KHz)
LSM303D on SPI bus 1 at 2 (11000 KHz)
ERROR [meas_airspeed] no MS4525 airspeed sensor connected
ERROR [ets_airspeed] no ETS airspeed sensor connected
nsh: sf1xx: command not found
INFO [px4io] default PWM output device
INFO [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS1 @ 57600B
px4flow [198:100]
WARN [px4flow] scanning I2C buses for deviceâŠ
INFO [mavlink] mode: Config, data rate: 800000 B/s on /dev/ttyACM0 @ 57600B
INFO [init] Mixer: /etc/mixers/quad_x.main.mix on /dev/pwm_output0
INFO [init] Mixer: /etc/mixers/pass.aux.mix on /dev/pwm_output1
nsh: attitude_estimator_q: command not found
INFO [lib__ecl] EKF IMU buffer length = 21
INFO [lib__ecl] EKF observation buffer length = 16
NuttShell (NSH)
nsh> INFO [lib__ecl] EKF using pressure height - commencing alignment
INFO [lib__ecl] EKF alignment complete
I donât see any output regarding the I2C_1 bus
So I have a set of questions:
How do I know if the I2C bus was started properly ?
How can I debug the I2C communication ?
Any suggestion is most welcome.
Thanks in advance
Have a nice day !
I just found the Pb.
The pb came from a friend using 2 of this px4flow, just he changed the default I2C @ of the module with the address solder pad on the back.
I removed the solder jumper and I now can see that px4flow module sarted properly.
I am still interested in the two previous questions:
Thanks in advance
