Finished first manual pid tuning and have quad flying fairly well. Altitude hold is cruising fairly well also. In position hold when loitering at the 5 m/s and let off the stick the transition from loiter to endpoint holding is very abrupt and it shakes the quad up pretty good. Excellent stopping and position hold I have to say but let say I want it to kind of slide into a hold rather than just lock up dead on the spot what would be the parameter to adjust? I have looked at the printed parameter list as well as tweaked a few things but donโt feel I am working with the correct parameter yet. Any advice? Thanks.
Try adjusting the maximum acceleration and deceleration values under multicopter position control.
Thanks I will check those out and see if they will help soften the transition into endpoint mode.
@dagar thanks for that. Reducing multicopter position control>MPC_DEC_HOR_MAX to 4 m/s/s from 10 m/s/s allowed the quad to decelerate slower and slide right into the hold position I wanted without making the gimbal bang against its limits.
