Proposal: Very light schema and transaction protocol for firmware negotiation with an HTTP endpoint.
HTTP rest server for firmware payloads
Firmware parameter metadata (no metadata if you flash from QGC right now)
Direct motor control access
Pedro-Roque: We need a direct interface to the motors. Currently, you can’t send a motor PWM of 2000, and we needed something that was easy enough to use
Action: Dev team has some feedback on implementation.
VTOL rate control improvements
Rebased and ready for testing, the test team will fly again.
UAVCAN support
Test team needs help setting up their test units; we don’t have proper documentation for setup on dev.px4.io
ESCs MotorId should start at index 0 and be unique
Motor 1: 0
Motor 2: 1
Motor 3: 2
Motor 4: 3
Nodeid can be random numbers as long as they are unique
Motor 1: 11
Motor 2: 12
Motor 3: 13
Motor 4: 14
Make sure to set the voltage to at least 20 on VOLT_PARAM
Action: Flight testing of UAVCAN vehicles should happen at least once a week
Action: Get UAVCAN hardware for CI and Developers
Localization
Lorenz will propose next week on PX4 dev call, there’s a massive push for localization and there are messages in the firmware that need localization
