I am having a problem where the PX4 (v1) is not outputting a PWM signal when the vehicle is ‘Armed’.
This is using the latest ‘Stable’ PX4 Firmware. ‘Master’ fails miserably at doing anything (crashes mid-boot) on the PX4, so i used the latest ‘Stable’ instead.
Note:
I calibrated the ESCs (Plush 30A) using the QGC calibration.
I set the PWM_MIN to 1400, no effect.
The motors DO flicker every ~1 second while disarmed (I believe it is just to keep the escs ready).
Quadrotor is in ‘+’ formation.
Any help?
If it is relating to the ESCs, how do I solve this problem (is the PWM frequency too high, if so how do i adjust in QGC or by other methods?)?
I would have uploaded the px4log file, but this system would not let me.
Does your ESC beep the correct initialization sequence after hooking up to pixhawk?
Some ESC don’t arm unless they first see a PWM under some threshold (see your ESC manual). I guess this is for safety reasons, to prevent props from spinning up immediately at arm. For mine it was 900, try setting PWM_MIN to a lower value in QGC?
