Using a very basic RPM sensor can I measure RPM in pixhawk ? The rpm sensor works digitally ( high and low states ) , can I use pixhawk Aux pins to read the pulses and use a counter to increment ?
Yes you can definitely do this. What’s the sensor?
You’ll need to write a little driver to read the data, and then publish an ESC status message. This will be logged automatically.
Thanks man…currently I’m using pwm_input.cpp ( driver code ) and I can find the rpm using the pulse time period. I can connect my sensor to AUX Pin 5 and using the variation in pulse duration I can calculate the propeller rpm.
For this currently I’m using pwm_input test command from the terminal. But this code doesn’t publish the value to the pwm_input topic ( there is no ORB_publish() ) . Secondly I want to run this code using ISR and start the driver as well as publishing time_period of pulses to the topic once the controller is powered on.
You could either create another “driver” (ISR or HPWORK) that reads from pwm_input (/dev/pwmin I think) or reimplements the portion of pwm_input you need.
I’m thinking of editing the pwm_input code itself. As of now pwm_input start will load/start the driver . Can i edit the code such a way that pwm_input start will start the driver as well as start the function pwmin_tim_isr(int irq, void *context) which will calculate the pulse time period using isr ? Then I can publish the data in the publish fucntion and the whole code will run in the background similar to a daemon app. Hoping thats possible
Is it possible to edit a driver code to a daemon app ?
Hi All,
I am trying to use the same file (pwm_input.cpp) for reading RPM. It works well but my Pixhawk board freezes/hangs randomly. I strongly suspect that my RPM reading module may be the reason. Due to safety concerns related to this random phenomenon, I am unable to go for flight.
Any further leads in this regard would be highly appreciated.
@Albin : Were you finally able to use pwm_input.cpp for reading RPM from your sensor?
It takes the advantage over direct sensing of PWM by MCU. Because it is basically I²C counter and offloads the MCU. Therefore it could be used even for high rpm propellers without risk of high MCU load.
