@Sn0west use the settings from the QAV250 (which are here) but make these different:
- MC_ROLLRATE_P = 0.025
- MC_PITCHRATE_P = 0.04
- MC_ROLLRATE_D = 0.001
- MC_PITCHRATE_D = 0.0005
Let us know what you get then.
Hi all, Iāve got a rig going with the following setup:
I have been testing over the past several days but today was the first really smooth test flight. I did add baro foam between the board and the frame plate, but otherwise the Pixracer is hard-mounted. I am using the PX4 QAV250 defaults for the most part. ESP8266 is very nice to use in lieu of the usual 3DR telemetry radio.
The only thing I havenāt finished up is the telemetry display on a Taranis running the latest OpenTX. I do use battery telemetry as a rule so I have that on the smart port as well.
Again, wonderful work guys!
When I have had uBlox issues and I know everything is wired correctly. I open uBlox uCenter and reset the GPS to defaults. Connect to the Flight Controller and boot. The Controller detects and configures the GPS as it requires.
It turned out to simply come down to weather, my working location, and the tight airframe confines. Now with the GPS on a very short rigid mast it fixes just fine when outdoors. Iāve been working with GPS while developing products for years but there is always more to learn!
I do have one of the RTFQ GPSās on the way as well but that might just end up on another Pixracer
Cheers.
It doesnāt work at all.
The default values in qgc do not match the list you gave me for qav 250. Strange isnāt it?
Here the screenshot of the values I tried.
The value MC_PITCHRATE_D = 0.0005 dose not exist.
Could the problem be a esc problem? I use bheli opto 20 amps with simonk firmware on it.
I use qgc 2.9.2 and the master firmware.
Are you using the wifi for your connection to the ground station while flying, or just for programming it? Have you done any range testing w/ the ESP8266?
I havenāt range tested. Iām a little careful flying since it is winter here and there is a lot of snow on the ground. I will say it is crazy the range those little chip antennas can get even just around the house!
Just wanted to say that I managed to get rid of my vibrations. So I just tuned my pidās in my basement, I have no ideas hoe it would fly.
Anyway Iām glad that Iāve fixed it.
Here are my settings. Just for the very basic basement setup.
I built my copter today, and sameā¦ It was oscillating wildly.
Sn0westās basement params got me in the air.
Motors are KDE 2304 2300 with 6x3 Graupner C-Props. Running on 3s.
Sn0west, please post any updated params, when you do more tuning.
Iām very confused by the flight modes, too. Coming from APMā¦
Is this normal for px4?
Safety switch was non functional. Lights solid when I power the copter, and no need to press it.
I canāt arm or take off in any mode other than Manual. I can switch to altctl in the air, but thatās difficult.
And, I canāt disarm in altctl mode!! This one was disturbing. I held the stick bottom left for a while. The props were not spinning. But, when I picked it up and it went unlevel, the motors jumped to life! If I switch back to manual, I can disarm.
Should the motors slowly spin when the throttle is down?
Is there a previous forum or manual with more info on configuring px4?
thanks for any help!
Ha Iām glad I could help someone
But as I said those values are not reliable and Iām not sure how they behave outside! I need a lot more time into PID tuning.
The stock PID are for biger copter with less thrust than race copters with powerful setups.
I never got a answer if there will be a way if tuning PID in the air with a nobe and a switch like in cleanflight. This would make life way easier.
Ther is a kill switch (RC_MAP_KILL_SW) this will stop all your motors.
I also would like to have a arming switch and that the motors are spining but I did not find out how to do it. I think itās not available at the moment.
Imagine you are at a race and the at the start you need to arme with sticks. Until you get in the air your opponents already finished the first lap of the race
And also here, I never got a answer, armingyour copter in a other modus than manual is apparently not possible, unfortunately. I would love to arm in acro modus butā¦no chanceā¦
Does your āsafety switchā work?
I thought maybe px4 didnāt use it.
But, I put APM on my pixracer, and still, the safety switch light immediately lights solid red, and I donāt have to press it. Usually it flashes until it is pressed.
Iām not sure if my switch is broken, or maybe its behavior is different on pixracer?
The safety switch is currently ignored by the PixRacer. What is your preference? Do you think itās necessary, or that the arming mechanism is sufficent?
Thanks!
I donāt think itās necessary. I just wanted to be sure there wasnāt something wrong.
Have any of the Ardu or PX4 devs taken the advice of others (like peabody124 of TauLabs) and got the OneShot stuff working yet? For a āracerā board, even if you refute its use, the ability to enable is a game changer for some folks.
What is the status on: āOneShot PWM output for new ESCsā?
āHere you can see the latency from an update from the gyro (MPU9250 IRQ) to the completion of the pulse is about 300 Āµs, which is much better than the several milliseconds with traditional asynchronous PWM.ā
Px4 supports it. Arducopter probably will in the next major release.
Can you link the relevant info for setup? I didnāt jump out at me on Google.
That was tough to find! (Iām not being sarcasticā¦ it really was)
https://groups.google.com/forum/#!topic/px4users/UWPFu9XuKzY
I have lost the ability to connect pixracer to QGC 2.8 while using the the setup panel for the ESP8266 WiFi Bridge when I changed from 921600 to 57600 baudā¦ QGC should be able to pick up the UDP link on boot up using 57600 so that I can use the setup panel to go back to 921600 and hopefully reconnect to QGC? So far I have had no luckā¦ What am I missing?
So Iāve just managed to test-hover my QR400 for the first time. No issues to report, everything seems to work as advertised - except that it doesnāt really keep to āPWM_MINā value. At idle throttle, giving roll/pitch/yaw input speeds up one respective pair of motors and completely stops the other, whereas I would expect the āthrottling downā motors to remain at PWM_MIN and keep spinning. But I donāt think itās a big issue, and it shouldnāt present itself in normal flight. (Before anyone asks: yes, the ESCs are calibrated properly - the lower PWM threshold is set at 1150 in BLHeli, and PWM_MIN in PX4 is set to 1175).
Iāve used the QAV250 preset. The frame is a Flyduino QR400 using Tiger MN2213-950kv motors, T9545 props, Littlebee 20A ESCs and a 4S Lipo. No oscillations or anything to report, stock PIDs seemed adequate (though the 30 second long living room hover is not much of a test).
Try the latest build of QGC: 2.9.2 is working well for me at 921.6K baud
It worked for me too at 921600 until I changed it 57600ā¦ I just donāt know how to get back to 921600ā¦
