Hi! My flight controller is oriented Yaw 270 then Roll 90. But there is no such orientation in list of available orientations during sensor calibration.
How can I set up for such configuration?
What I did so far is added new orientation to rotation.h
, rotation.cpp
, sensor_params.c
. And now as I’m selecting my new custom orientation number for SENS_BOARD_ROT
parameter I’m seeing HUD shows irrelevant orientation. Also plane position during calibration is shown incorrect.
In order to nail down the problem I’m just copied the code from ROTATION_ROLL_270_YAW_270
to my newly created orientation. And still see some irrelevant orientation which is nether orthogonal to ground fixed frame.
I tested the same in sitl_gazebo
. Modified orientation of IMU to be consistent with ROTATION_ROLL_270_YAW_270
, ensured proper HUD readings. Then as I change SENS_BOARD_ROT
to my custom number (which uses the same exactly code copy pasted from ROTATION_ROLL_270_YAW_270
) I starting seeing HUD drifts to some irrelevant position.
Any hints? What have I missed?
I started an issue in Firmware bug tracker.
The code changes can be seen in commits to firmware (1, 2) ans sitl_gazebo.
One more issue found during investigation is standard_vtol
irrelevant orientation even with standard SENS_BOARD_ROT
= 26. While iris
model works as expected for SENS_BOARD_ROT
= 26 and still not works for the newly added orientation the same way as real hardware not works either.
