Quad has a pixhawk with latest version of px4 flashed. quad arms but doesn’t lift off. flips over after a threshold throttle value. props are in the right direction and motor spin is correct on all four.
Help and suggestions guys?
Thanks!
Thanks!
Check followings,
It flew so never mind that. the problem I wired the escs to the PWM conventionally as opposed to 4-1-2-3 used in ardu pilot and px4 stacks.
Thanks anyway though!
@ sanderux
Hi i too have a similar issue where my Quadcopter is not lifting…i feel there is enough thrust for the motors to lift and the props are well connected…Do you have any suggestions…Can the EKF2 filters create lift issue in theory …Mine is throttling on the ground at considerable speed but not lifting the quad…I suspect the assembled cells but it used to work well before or should i bypass the BMS to check if it is a faulty BMS … …
