Has anyone tried the new released Pixhawk2.1 with PX4 flight stack? I have configured the copter using QgroundControl, everything seems fine until I tried to arm the copter, i kept getting the error message preflight failure: GPS Receiver Missing, and the copter is not able to arm. I have searched through the parameter list and made sure that GPS check is disabled for arming.
I seeā¦ that means the problem might not come from the GPS. There is another message that simply says preflight check failed, without specifying what the error is. May I know how do I check the specific error that prevent the copter from arming?
How do you have it connected? Right now it has to be the larger GPS 1 port which breaks out to GPS, MAG, Safety button. We donāt currently automatically start the gps driver on the 2nd smaller port.
Iām experiencing the same problem on the Pixracer with firmware v1.5.2. There also seems to be a problem with 3dr telemetry modules Iām using. They wonāt connect. I donāt have this problem when using v1.5.1.
Hi, i dont use PX4 for my pixhawk 2 but with ardupilot I can not get my telemetry radios to connect either. I tried to flash the px4 firmware to see if it made a difference but it still wont keep a connection. I have tried switching radios firmware and portsā¦ makes me think its a pixhawk 2.1 issues??
Niker: this may be a connection or cabling issue, have you checked the TX and RX pins are connected to the right ports? In the documentation of Pixhawk2 you can find out the exact TX and RX pins for telem port.
If it is still not working, you may want to find out whether there is signal coming out from the ports. If not, then it is likely a hardware problem.
Hi dagar,
I did not connect it to any GPS, so I guess the error message is common, and it is something else that caused it not able to armā¦ But I canāt figure out what is the error that caused the preflight failure.
I help loaded the latest master into pixhawk2, the message of GPS Missing disapeared. However, I am still not able to arm and the message is Not Arming: preflight check failed. I suspect it is not something about GPS. All my sensors and RC channels have been calibrated and seem to be normal, so I caanot locate the root of the problem.
I am not a programmer. But if you can help with this issue it would be great. I am currently doing my university project and I am stuck with this problem.
