Farin
April 2, 2019, 6:19pm
1
Hi everyone,
I was trying to use pwm 5 and 6 on the omnibus f4pro.
This should be pretty straight forward using the aux 1 and aux 2 chanels, however things are not working.
I took a lok at the firmware and found in
* Copyright (c) 2018, 2014 PX4 Development Team. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. Neither the name PX4 nor the names of its contributors may be
* used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
This file has been truncated. show original
and
* Copyright (c) 2012-2018 PX4 Development Team. All rights reserved.
* are met:
* distribution.
that only 4 pwm signals are configured.
Uncommenting the lines relative to pwm 4 and 5 didn’t work. I could build and flash the firmware, but still no signal on those ports.
I don’t know much on PX4, so was wondering if anyone has an idea on how I can get this to work.
Cheers,
Andre
I’m going to ping @bkueng hoping that he might have an idea.
bkueng
April 5, 2019, 9:22am
3
It needs a bit more, but w/o digging into it myself, I cannot tell you what exactly.
One thing I can say is that RX of UART4 is configured on PWM 5, so you will have to disable that UART.
Farin
April 5, 2019, 10:38am
4
Thanks for the hint.
I’ll let you know how it goes.
It’s an old topic but is still an issue. Did you fix it? Is it possible to enable PWM 5 & 6 without compiling source code?
