Hello everyone. I see the following error when attempting to install pymavlink:
user@user-XPS-15-9570:~/src/Firmware$ sudo pip install pymavlink pyserial
/usr/local/lib/python2.7/dist-packages/pip/_vendor/requests/__init__.py:83: RequestsDependencyWarning: Old version of cryptography ([1, 2, 3]) may cause slowdown.
warnings.warn(warning, RequestsDependencyWarning)
The directory '/home/user/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/user/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting pymavlink
Downloading https://files.pythonhosted.org/packages/07/e3/fa12ec6d31785f51d8530516b404b2a966b23ecc0f1626ce7a4353d12891/pymavlink-2.2.11.tar.gz (3.0MB)
100% |ββββββββββββββββββββββββββββββββ| 3.0MB 12.2MB/s
Requirement already satisfied: pyserial in /usr/local/lib/python2.7/dist-packages (3.4)
Requirement already satisfied: future in /usr/local/lib/python2.7/dist-packages (from pymavlink) (0.16.0)
Requirement already satisfied: lxml in /usr/local/lib/python2.7/dist-packages (from pymavlink) (4.2.5)
Installing collected packages: pymavlink
Running setup.py install for pymavlink ... error/home/user/src/Firmware/mavlink/include/mavlink/v2.0/message_definitions
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-n9_Ziu/pymavlink/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-Gz2MbY/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
No XML message definitions found
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-n9_Ziu/pymavlink/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-Gz2MbY/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-n9_Ziu/pymavlink/
I tried to set the MDEF environment variable:
user@user-XPS-15-9570:~/src/Firmware/mavlink/include/mavlink/v2.0/message_definitions$ export MDEF=`pwd`
user@user-XPS-15-9570:~/src/Firmware/mavlink/include/mavlink/v2.0/message_definitions$ echo $MDEF
I installed all the dependencies but Iβm unsure how to proceed now.
