I thought folks might find this interesting. We recently did some PX4 fixed wing testing with firmware based on 1.8.0 where we forced the GPS driver to stop and watched the vehicle behavior. We would restart the GPS driver and watch where the vehicle position jumped to as a measure of how far off the EKF navigation solution had wandered.
Amazingly we had one loiter remain stable for > 6 minutes before the global position failsafe finally kicked in.
Based on this log (and a couple others we’ve done) I think the EKF position error estimate is optimistic, at least for our hardware setup and flight profiles.
It’s indeed a nice experiment. Thank you for sharing the results; which I’ll look into more details later tonight. According to the logs, the flight time was over 10 hours. Is that correct? Are you using solar cells? And, are you using a PixRacer as FC?
I have a xvert tailsitter which I fly in stabilized mode without gps. I also fly acro including loopings, steep turns, many consecutive circles… you notice that the attitude solution drifts slightly but it does not impose an issue and recovers really fast once you level out. So I’m not surprised by the above results.
