Hey people.!
I am using an mRo x2.1 v2, running on Windows with cygwin toolchain.
When I try to upload my code (or even any example code - px4_simple_app), it goes into and endless loop when trying to locate the bootloader.
Here's what I did:
I build the code make auav-x21_default
The console builds it successfully
I try to upload it make auav-x21_default upload
Here is the output :
ninja: Entering directory `/cygdrive/c/PX4/home/Firmware/build/nuttx_auav-x21_default'
[0/1] uploading px4
Loaded firmware for board id: 33,0 size: 1613569 bytes (77.55%), waiting for the bootloader...
Attempting reboot on /dev/ttyS0 with baudrate=57600...
If the board does not respond, check the connection to the Flight Controller
I tried changing a cable, switching a port and the fix mentioned at https://docs.px4.io/en/flight_controller/mro_x2.1.html#px4-bootloader-issue.
Also, I can access the nsh terminal using QGC, but not using PuTTY.
Thanks.!
