Hello everyone, hope you’re all doing well. My motors do not spin.
When I hook up the motors to the receiver the motors spin and I can control the throttle, but when I hook up the ESCs to the PX4 the motors don’t spin. (I believe the wiring is correct, also soldering is not the issue).
You can see a picture of the setup here: https://ufile.io/a27rq
Does anyone know if the PX4 sends wrong signal to the ESCs? or what’s the problem?
My setup:
Flight Controller w/ GPS - Pixhawk PX4 32Bit ARM Flight
Motors - Turnigy Multistar 4822-490Kv 22Pole Multi-Rotor Outrunner
(https://www.amazon.com/gp/product/B00MIYXR2O/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1)
ESCs - Turnigy MultiStar 30A BLHeli-S Rev16 V3 ESC 2~6S (Opto)
(https://hobbyking.com/en_us/blheli-s-30a-2-6s.html)
Battery - Multistar High Capacity 16000mAh 6S 10C Multi-Rotor Lipo Pack XT90
Radio - FrSky 2.4G ACCST Taranis Q X7 16 Channels Transmitter Black
(https://www.amazon.com/FrSky-ACCST-Taranis-Channels-Transmitter/dp/B06XQWQ7C3/ref=sr_1_1?s=toys-and-games&ie=UTF8&qid=1525570349&sr=1-1&keywords=q7x)
Receiver - FrSky Taranis Compatible Receiver X8R 8-channel 2.4ghz ACCST&RSSI&SBUS Easy To Use Receiver
(https://www.amazon.com/FrSky-Taranis-Compatible-Receiver-8-channel/dp/B00RCAHHFM/ref=sr_1_1?s=toys-and-games&ie=UTF8&qid=1525570392&sr=1-1&keywords=x8r+receiver)
Ground Control - QGC
Thank you so much.
